Blocking RSS News Feeds
Windsun
Solar Expert Posts: 1,164 ✭✭
Some people find the RSS news feeds annoying, if you want to block them all so they don't show up in "new messages", just go to the User CP and add "RSSfeed" to your ignore user list. 8)
Re: Blocking RSS News Feeds
Thanks . They do get annoying to me . -
What I would like to do is block the RSSfeeds threads from showing up in "New Posts" and "Today's Posts". Is that possible?
VT as a stop gap measure I now go to FORUM tab, click on RSS feeds, go to FORUM TOOLS ( right side), use MARK FORUM as READ, gonzo...
hth
Eric
Re: Blocking RSS News Feedswestbranch wrote: »VT as a stop gap measure I now go to FORUM tab, click on RSS feeds, go to FORUM TOOLS ( right side), use MARK FORUM as READ.....
Does this still work ? I've only been able to mark ALL forums read, and adding RSS to the ignore, still lists all the postings.
I think the new forum SW does not allow markign just 1 sub-forum as readPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Blocking RSS News FeedsDoes this still work ? I've only been able to mark ALL forums read, and adding RSS to the ignore, still lists all the postings.
It works. You have to go to that section of the forum, where all the threads are listed. There's a "Forum Tools" sub menu just under the forum heading (in the blue bar). Second choice is "Mark This Forum Read". -
Re: Blocking RSS News FeedsCariboocoot wrote: »It works. You have to go to that section of the forum, where all the threads are listed. There's a "Forum Tools" sub menu just under the forum heading (in the blue bar). Second choice is "Mark This Forum Read".
Thanks . Didn't know about the lower level MARK functionPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I just read through the regular threads and then hit Mark Forums Read to clear out the RSS feed (if there are a lot).
A major waste of byte babble !
Post how to Shut off In IE X
Firefox , gravel 2 report ! Please ! -
Try this link:
http://forum.solar-electric.com/profile.php?do=ignorelistAdd a Member to Your List...
User Name
Add "RSSfeed" to the field, hit OK (things "go blank").
Refresh (or click the link above), and you should see a list of ignored users.To remove a user from your ignore list, un-check the box associated with their name and click the 'Save Changes' button.
To add a user to the list, enter their name into the empty text box and click 'Okay'.
Ignore List
Check / Uncheck All
Thank You BB
RSSfeed is / posts way
- 234 Forum & Website
