Blocking RSS News Feeds
Windsun
Some people find the RSS news feeds annoying, if you want to block them all so they don't show up in "new messages", just go to the User CP and add "RSSfeed" to your ignore user list. 8)
  • TOMMYB1
    TOMMYB1 Registered Users Posts: 6
    Re: Blocking RSS News Feeds
    Thanks . They do get annoying to me .
  • vtmaps
    What I would like to do is block the RSSfeeds threads from showing up in "New Posts" and "Today's Posts". Is that possible?
    VT as a stop gap measure I now go to FORUM tab, click on RSS feeds, go to FORUM TOOLS ( right side), use MARK FORUM as READ, gonzo...
    hth
    Eric
    westbranch wrote: »
    VT as a stop gap measure I now go to FORUM tab, click on RSS feeds, go to FORUM TOOLS ( right side), use MARK FORUM as READ.....
    Does this still work ? I've only been able to mark ALL forums read, and adding RSS to the ignore, still lists all the postings.
    I think the new forum SW does not allow markign just 1 sub-forum as read
    mike90045 wrote: »
    It works. You have to go to that section of the forum, where all the threads are listed. There's a "Forum Tools" sub menu just under the forum heading (in the blue bar). Second choice is "Mark This Forum Read".
    Thanks . Didn't know about the lower level MARK function
    BB. Super Moderators, Administrators Posts: 33,493 admin
    I just read through the regular threads and then hit Mark Forums Read to clear out the RSS feed (if there are a lot).
  • CDN_VT
    CDN_VT Solar Expert Posts: 492 ✭✭✭
    A major waste of byte babble !
    Post how to Shut off In IE X
    Firefox , gravel 2 report ! Please !
    Try this link:
    http://forum.solar-electric.com/profile.php?do=ignorelist
    Add a Member to Your List...
    User Name
    Add "RSSfeed" to the field, hit OK (things "go blank").
    Refresh (or click the link above), and you should see a list of ignored users.
    To remove a user from your ignore list, un-check the box associated with their name and click the 'Save Changes' button.
    To add a user to the list, enter their name into the empty text box and click 'Okay'.
    Ignore List
    Check / Uncheck All
  • CDN_VT
    Thank You BB
    RSSfeed is / posts way
