Surrette S-530 Electrolyte Volume
tallgirl
Solar Expert Posts: 413 ✭✭
Does anyone know the total volume of electrolyte in an S530?
I was asked to do maintenance on a system and the batteries appeared to be about as empty as can be, but I'd like to quantify for the customer just how completely empty they were.
Re: Surrette S-530 Electrolyte Volume
That begs the question, Drained, leaked or boiled out ??
Sorry I don't know their volume.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Surrette S-530 Electrolyte VolumeThat begs the question, Drained, leaked or boiled out ??
Boiled out. Customer had the sell voltage set to 56.4 and no temperature sensor and no water added in over a year.
And this is in Texas where batteries can and do get over 100F on a regular basis. You can do that math. -
Re: Surrette S-530 Electrolyte VolumeBlackcherry04 wrote: »Wet weight 117, Dry Weight 90 , Electrolyte, best I can tell is 8.34 lb per gallon. 27 lb of Electrolyte = 3.23 gallons. Don't hold me to it, just a wild guess.
www.rollsbattery.com/pdf/S-530.pdf
Thanks -- I didn't know if "dry" was with or without however much paste and how that changed the weight of whatever made them "wet".
The batteries needed 1.75 gallons to get back to "full". I filled them under the theory that "batteries that are full and maybe work are better than batteries that are mostly empty and definitely don't work."
The customer will have to decide how quickly to replace them ... -
Re: Surrette S-530 Electrolyte VolumeThanks -- I didn't know if "dry" was with or without however much paste and how that changed the weight of whatever made them "wet".
WOW! What a waste of what had been good batteries! So sad. -
Re: Surrette S-530 Electrolyte VolumeBlackcherry04 wrote: »I am not sure if it's correct or not, so don't take it to the bank.
I came up with numbers somewhere around there, so I was already on my way to the bank with something like that -
Re: Surrette S-530 Electrolyte Volumewaynefromnscanada wrote: »WOW! What a waste of what had been good batteries! So sad.
Yup. Date code was 10/08. Still in the prime of their life ...
- 654 Solar Water Pumping
