Mount Critique
Fatawan
Solar Expert Posts: 71 ✭✭✭
I am zeroing in on my system design. I think I am going with the Sanyo HIT panels and Enphase 210's. I plan to go with 48 panels mounted in 8 rows of 6 each. I plan to mount the panels using 1 1/2" schedule 40 pipe into 12" concrete pillars. I will have three rows horizontally. The vertical bars will be made of aluminum 8020 extrusions u-bolted to the horizontal schedule 40 pipe. I'll use commercially available clips bolted to t-nuts in the 8020, and use the same t-nuts to mount the inverters. I have attached my crude side view.
Please critique and add whatever might be useful.
Re: Mount Critique
Cross bracing? (X or diagonal)?
Re: Mount Critique
Ah yes, bracing. I would imagine the whole tall row would need braced to one another, and perhaps back row to middle row? Is there somewhere to look up guidelines for bracing? -
Re: Mount Critique
Make sure the pillars are well anchored, or really heavy. The wind loads can be tremendous. Figure about 10lb/sqft of wind pressure. -
Re: Mount Critique
What he said...
Yes depending on location wind might well be a really problem, we had 60mph straight line winds about 2 weeks ago, my panels were fine I have a ground mount with cedars and then my cabin, behind the panels, also a steeper orientaion for peak winter sun.
The 4x8 roof over the archery range, broke the 4 - 4x4 posts at the ground. It was a new roof on older posts, but still quite impressive, it was just a roof out in the middle of a field.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Re: Mount Critique... it was just a roof out in the middle of a field.
That's the worst situation you can have. If at all possible, put sides on the structure. Even slat sides will break up the wind and reduce the sail effect. -
Re: Mount Critique
Yeah my neighbor put up a gazebo about 18 X 18 on just a set of framed up posts(2X4 box about 12 inch square with sheathing and stucco) , and the city would not approve the plans because of wind loading and lack of racking bracing. He put it up anyway.
Re: Mount Critique
He may find it in Kansas one day!Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Re: Mount Critique
Anyone familiar with this mounting system? It's kind of what I had in mind, but I have no idea where it came from. -
Re: Mount Critique
Looks like a spiffy ground mount, homemade ?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 230 Forum & Website
