battery shunt
andy300z
Solar Expert Posts: 39 ✭
Hello,
I am in the process of purchasing the trimetric 2020 battery monitor . I have a 24v system which will be 4 batteries 12v appx total 400ah. This is a starter set up which i will be adding more batteries in the future. Please advise on which shunt i should get a 100a or 500a. Thanks
Re: battery shunt
I believe that you will need the 500 amp shunt for a system that size.Please advise on which shunt i should get a 100a or 500a. Thanks -
Re: battery shunt
Shunts are sized acording to how much current (amps) you expect to pull thru them. A 48V system that uses less current, can use smaller shunts.
I would not try to get a shunt to match the peak surge current (motor starting), but would tend to size it to sustained loads.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: battery shunt
Remember that shunts have voltage drop too. To small of one may cause problems with surf currents.
- 234 Forum & Website
