if you were buying a couple of 6 volt batts
ws9876
ws9876 Solar Expert Posts: 453 ✭✭✭
for a 300 watt backup inverter setup 12v .....what would you buy ...???and if you lived in MT/Wy
(shipping)???
  • Kamala
    Kamala Solar Expert Posts: 452 ✭✭
    Re: if you were buying a couple of 6 volt batts
    Depends on the number of hours you expect the inverter to deliver power to an, as yet, unspecified load.
    Not knowing the exact requirement/expectation, I'll suggest a single 100AH 12v battery. Maybe run a small TV and a light for a few hours.
    What do you plan to run with it, and recharge it with ?
  • icarus
    Not to be repetitive, but tell us your loads.
    Suggesting a battery with out knowing the loads is like,, well you know, make up your own analogy!
  • ws9876
    it will run 2 lights cf
    1 TV 100 watts
    and 1 laptop using 15 watts
    for about 1-2 days
    I am thinking AGM
    ws9876 wrote: »
    1 TV 100 watts
    for about 1-2 days
    I am thinking AGM
    Uh, it's more like this:
    2 13W CFL's - for how long per day?
    1 100W TV - for how long per day?
    1 15 W Laptop - for how long per day?
    Otherwise you're trying to calculate without necessary info; the actual hours use per day. You might end up with 141 Watts * 24 hours = 3.3 kW hours, which is unlikely to be what you actually need because you won't be running everything continuously all day.
    I would not by AGM type batteries unless you need the "safety" factor of the sealed units. Why? Because this is a first system and mistakes are likely to be made. Standard FLA deep cycles (like golf cart batteries) are more "forgiving" of mistakes and don't cost as much per Amp hour.
  • cfcw
    cfcw Solar Expert Posts: 25
    I bought my golf cart batteries at the local Sam's club. Costco also has them. They are about $75.00 each
  • icarus
    2 15 watt cfl for 2 hours = 60 watt/hours (wh)
    100 watt TV for 2 hours= 200 wh
    Laptop 15 watts for 2 hours= 30 wh. (Does it only draw 15 watts?)
    Total load 290 wh/day, assuming your figures are correct.
    290 wh= ~ 23 amp hours @ 12 vdc
    If you only wish to draw your battery down 25%, you should look for a battery in the 100ah range. A pair of golf cart batteries would be about 250 ah.
    That said, I think you are underestimating your loads. I suspect that your Lap top draws closer to 60 watts, and the TV might be closer to 150. Do you have a Kill-a-watt meter to confirm your loads?
    PS I don't know too much about AGMs, but consider the price comparison carefully given what you expect to do with them. I also suggest you read the following links.
    http://www.windsun.com/Batteries/Battery_FAQ.htm#Lifespan%20of%20Batteries
    http://www.batteryfaq.org/
  • ws9876
    i do have a kiil watt lap is 15-20 tv is 95 tv 5 hrs lap 4 hrs lites 6 hrs..
    what about Crown ??? 200 ah
  • icarus
    I would buy a pair of reasonable quality golf cart batteries, Trojan or something similar, that you can find relatively cheap at the discount store. Then you have to have a way to keep them fully charged, ideally with a 3 stage charger with temperature correction like an IOTA or a Xantrex TC series.
  • ws9876
    I heard Trojan had gone downhill, at least awhile back. I heard Crown was now better. Yes.???no???
    Anyone in Salt Lake city know of a good source there...?? I go there every few months...
