if you were buying a couple of 6 volt batts
ws9876
Solar Expert Posts: 453 ✭✭✭
for a 300 watt backup inverter setup 12v .....what would you buy ...???and if you lived in MT/Wy
(shipping)???
(shipping)???
Re: if you were buying a couple of 6 volt batts
Depends on the number of hours you expect the inverter to deliver power to an, as yet, unspecified load.
Not knowing the exact requirement/expectation, I'll suggest a single 100AH 12v battery. Maybe run a small TV and a light for a few hours. -
What do you plan to run with it, and recharge it with ?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Not to be repetitive, but tell us your loads.
Suggesting a battery with out knowing the loads is like,, well you know, make up your own analogy!
Tony -
it will run 2 lights cf
1 TV 100 watts
and 1 laptop using 15 watts
for about 1-2 days
I am thinking AGM -
Re: if you were buying a couple of 6 volt battsit will run 2 lights cf
1 TV 100 watts
for about 1-2 days
I am thinking AGM
Uh, it's more like this:
2 13W CFL's - for how long per day?
1 100W TV - for how long per day?
1 15 W Laptop - for how long per day?
Otherwise you're trying to calculate without necessary info; the actual hours use per day. You might end up with 141 Watts * 24 hours = 3.3 kW hours, which is unlikely to be what you actually need because you won't be running everything continuously all day.
I would not by AGM type batteries unless you need the "safety" factor of the sealed units. Why? Because this is a first system and mistakes are likely to be made. Standard FLA deep cycles (like golf cart batteries) are more "forgiving" of mistakes and don't cost as much per Amp hour. -
I bought my golf cart batteries at the local Sam's club. Costco also has them. They are about $75.00 each -
2 15 watt cfl for 2 hours = 60 watt/hours (wh)
100 watt TV for 2 hours= 200 wh
Laptop 15 watts for 2 hours= 30 wh. (Does it only draw 15 watts?)
Total load 290 wh/day, assuming your figures are correct.
290 wh= ~ 23 amp hours @ 12 vdc
If you only wish to draw your battery down 25%, you should look for a battery in the 100ah range. A pair of golf cart batteries would be about 250 ah.
That said, I think you are underestimating your loads. I suspect that your Lap top draws closer to 60 watts, and the TV might be closer to 150. Do you have a Kill-a-watt meter to confirm your loads?
PS I don't know too much about AGMs, but consider the price comparison carefully given what you expect to do with them. I also suggest you read the following links.
http://www.windsun.com/Batteries/Battery_FAQ.htm#Lifespan%20of%20Batteries
http://www.batteryfaq.org/ -
i do have a kiil watt lap is 15-20 tv is 95 tv 5 hrs lap 4 hrs lites 6 hrs..
what about Crown ??? 200 ah -
I would buy a pair of reasonable quality golf cart batteries, Trojan or something similar, that you can find relatively cheap at the discount store. Then you have to have a way to keep them fully charged, ideally with a 3 stage charger with temperature correction like an IOTA or a Xantrex TC series.
Tony -
I heard Trojan had gone downhill, at least awhile back. I heard Crown was now better. Yes.???no???
Anyone in Salt Lake city know of a good source there...?? I go there every few months...
- 228 Forum & Website
- 618 Discussion Forums/Café
