Emergency Fix. SunSaver Broke
Help.
My Sun Saver 6 stopped putting out. Voltage to battery is zero. Input voltage is 17.6 V from single 85 Watt panel. Can I bypass the controller for a few days without problems?
Carl Carlson
Carl Carlson
Re: Emergency Fix. SunSaver Broke
Put a 5 amp capable blocking diode in series with panel. (I assume you are talking about a 12v battery)
Check battery voltage during day to make sure it doesn't get much over 14.2 vdc. -
Bypassing the controller is OK, if you watch the voltage with a meter. Gets tricky if you have a expensive AGM battery, check that meter often.
On a working controller, you can bypass with a jumper from PV + to Bat + but if your controller is broken, you just might fry a fuse or worse. Any internal controller fuses you should check ?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
When you say "stopped putting out", how did you measure it?
If you try to just measure it with no battery connected to the controller, it does not mean much, as the controller has to have a battery hooked up for it to turn on and operate. -
Re: Emergency Fix. SunSaver BrokeWhen you say "stopped putting out", how did you measure it?
uh huh! The OP must have battery voltage on the CC ! If the fuse is open, why did it open?"we go where power lines don't" Sierra Nevada mountain area
Thanks for the info.
Carl
- 654 Solar Water Pumping
