Non electric gas space heater??
icarus
Solar Expert Posts: 5,436 ✭✭✭✭
I have been charged with finding a completely non electric propane gas space heater for some folks. I have always used Empires in the past, (or Rinnais where I have power) but I am wondering if anyone has any experience with any other units. I have had problems with Empires in the past, both with gas valves that quit, or leak, as well as direct vents that blow out if they are subjected to much wind. This one will live in a quite windy location. Conventional "B" vent systems might be considered, but are not preferred for a number of reasons. Any thoughts from other off grid folks out there?
Once again, thanks for all the considered response,
PS I found one call a "Robur" They make a small one ~7kbtu that uses no power and vents (intake and exhaust) through a ~4" hole, 78% ef.http://www.houseneeds.com/shop/HeatingProducts/RoomHeaters/Robur/roburgaswallspaceheaterstech.asp
Re: Non electric gas space heater??I have been charged with finding a completely non electric propane gas space heater for some folks. I have always used Empires in the past, (or Rinnais where I have power) but I am wondering if anyone has any experience
Tony, what is the issue with power and the Rinnais? None of my Rinnais use power.
Rinnas have been very dependable, with the only issue being dust that gets into the ignition area, a vey simple clean and fix. -
The only Rinnais that I am familiar with are the fan forced direct vent units. (The non-vented units are NOT acceptable). I don't know of a Vented Rinnai that uses no power. Perhaps I will do a bit of a search.
PS I can't seem to find any that both vent and use no power.
T -
Tony try these guys for eskabe heaters
The main contact in Canada is Hank Vodarek at H.A.S. Enterprises in BC. His number is 250-497-5332. One dealer is Gemco in Alberta. Here is their contact info:
http://www.profilecanada.com/companydetail.cfm?company=180652_Gemco_Fireplaces_Ltd_AB
Original Message
Subject: vented heater dealers
Date: Thu, October 29, 2009 10:11 am
To: info@eskabeusa.com
do you have a Canadian web site and/or Canadian dealers, distributors?
thanks
Eric
Eric,
Thanks for the link. I'll look into it. (As I suggested off line) these still vent through a huge 7" hole like the Empires. They do have a modulating gas valve like the Rinnais however. They also make a bigger (no power) unit than Robur. -
try williams heaters. i just bought a 30k btu, propane, gravity circulation, microvolt thermostat. direct vent, wall mount, no power required. have not hooked it up yet. cost was $900 canadian retails approx $1300. -
The problem with the Empires, the Williams, the Cozys is that they have a huge intake/exhaust hole through the wall. The problem that I have had with these type of heaters in the past is their tendency have their pilot lights blow out in high wind situations. They also can be very difficult to light in the wind as the draft can be REAL strong.
The particular installation that I am looking at has very significant wind loading and I am concerned that I will be repeating the problems I have had in the past with other units.
The Robur unit vents through a very small hole ~2" like the Rinnais, but the unit is too small for my apllication (~7k btu) The high ef Williams (non electric) units are also too small.
The eskabe units are nice because they have modulating gas valves like the Rinnais with I see as an advantage but they also vent through a 7" hole and I am worried about the wind.
Thanks for all the suggestions, and keep them coming. Life would be easier if there were power, then it would be a Rinnai.
Tony -
I am wondering about this same issue... would it be possible to power a rinnai with 12V? -
The Rinnais cannot be made to run off of 12vdc except through an inverter. I believe it was Eric (westbranch) who had an e-mail conversation with Rinnai and they don't make any 12vdc models. Too bad! I think the issue is that the control boards use a number of different voltages for different functions.
Running one on a Pure sine wave inverter would be no problem, and fairly efficient.
Tony -
yup, in the neigbourhood of 60 W on AC
Eric
Re: Non electric gas space heater??westbranch wrote: »yup, in the neigbourhood of 60 W on AC
Remember it's typically coldest just before dawn, ie if you are normally idling your inverter add the draw of the inverter.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
