500 gallon stationary fuel tank - tiny leak
softdown
softdown Solar Expert Posts: 4,062 ✭✭✭✭
In the Weeds or what?
Do we have any plumbers here? I can pretty easily take a pic if someone feels they are qualified to assess this.
At the base there is a 1 1/2" outlet that is reduced to 1". But the leak is exceedingly small and almost impossible to pinpoint. I'd estimate my losses at ~ 8-10 drops/day. Not enough to even drip. Just enough to gradually form a droplet after a few hours.
Efforts to tighten made it leak much, much worse. So that's a huge no go. It even makes me consider leaving it alone.  Bought some JB Weld for fuel tanks but I just can't find the source of the leak. It is either too small or too wide spread - perhaps the bottom half of the 1 1/2" outlet?
Oddly there would seem to be a few places where the leak could be originating. The tank was made in China - I suspect their connections may be different than what I am accustomed to. Even considering a compression fitting rather than the standard threaded fitting. Which makes me somewhat leery.
Any plumbers here?
    Diesel , fuel oil or gasoline  ?
    I'd be tempted to scrub with acetone and use an epoxy fuel tank sealer
    Can you empty the tank to do repairs (or wait till it's nearly empty ? )
  • softdown
    Can't empty without another tank.  Gasoline.
    Scrubbed thoroughly of course. Leak is just too small to pinpoint.
    JB Weld is a 2-part epoxy. A lot of adhesives do not work with fuel. This is for fuel. I'd have to use a great deal unless I can pinpoint the leak. Three different areas could be the leak.
    I'm not even sure that it is more than 1-2 drops/day. It does not drip drop.
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,191 ✭✭✭✭
    How many gallons are in the tank?
    I always have more questions than answers. That's the nature of life.
  • mcgivor
    This is one of the best products to use with fuel tank leaks https://www.amazon.com/Seal-All-380011-Adhesive/dp/B0000AXYZG
  • softdown
    edited May 2020 #6
    About 485. The leak started due to the stress of washboard roads. I think it is leaking less each day. Put a paper plate under it a few hours ago. Not a drop.
    If I lose 1-2 drops/day - that will take a pretty long time to drain. About 35,000 years. I likely will not live that long. I figure my consciousness will fit in an affordable $3.49 32GB USB stick. But the stick lasts how long?
    If metal tank, water in bottom, pinhole rust? If so, then the tank is not really structurally sound now?
  • softdown
    That is definitely not the issue. A pinhole would be exceedingly easy to find and fix. The tank is kind of newish - just wasn't made for washboard roads - not much is. Snapped a 9.75 axle a couple years ago.
    This is a couple drops/day folks. Not a "structurally unsound" tank. Though I knew it was coming.
  • geosierranevada
    geosierranevada Registered Users Posts: 57 ✭✭✭
    Softdown
    It may sound silly but rub a bar of ivory soap on the leaking area, it works but I have not done it since 1972.
    George.    Have a nice day
    Off grid for 20 years. 5KW panels, Trace sw4024, Bergy XL1 wind generator, 3 EG4 Lifep04 200amphr batteries  3 SQF 2 well pump, 12kw back up gen.  Not easy living in the wilderness but it keeps you busy
  • solar_dave
    Softdown
    Yeah when I was a kid I had a '61 t-bird with a rusty tank, soaped it about once a week or after a rain. LOL
  • Marc Kurth
    I am guessing that you burn a lot of gasoline in order to use it up before it ages out, even with a stabilizer additive.
  • softdown
    edited May 2020 #12
    Yes - nothing is close for one thing. Accounts are a 500 miles round trip. Torn up rentals are a 5000 miles round trip. If I sen money to S Florida without supervising - it pretty much disappears.
  • softdown
    It quit leaking. Not a drop in 28 hours. Everything is bone dry. What a relief!
