Energy usage caused by malfunctioning security light?
softdown
Solar Expert Posts: 4,078 ✭✭✭✭
The LED light is rated at "25 watts" though it seems awfully bright for 25 watts. The light used to be motion activated. Now it shines all the time as noted in more edit. During daylight hours the gears work constantly in moving the light head back and forth.
So it is malfunctioning in two ways. I have no easy way of ascertaining power consumption by the gear that constantly move the light head - which might weigh a bit over one pound by my estimation.
EDIT: The light is on 24/7.
The motion security lights you buy at Costco seem to last around 3-5 years before they go bad... Say your light is now drawing 30 Watts 24x7:
- 30 Watts * 24 hours per day * 30 days per month * 1 kWH / 1,000 WH = 21.6 kWH per month
- 21.6 kWH per month * utility rate (say $0.20 per kWH) = $4.32 per month
Is this what you were looking for?
Thanks - gives me an idea on the light. The gears are always turning the head and I wonder about that power usage as well. These were pricey security lights. They are motion activated and turn the light towards the motion when working properly. Plus they record video of the motion on Micro SD cards. They are no longer available. I bought a lot of $pare$ but many things disappeared when I left my shipping container open one fateful night.BB. said:The motion security lights you buy at Costco seem to last around 3-5 years before they go bad... Say your light is now drawing 30 Watts 24x7:- 30 Watts * 24 hours per day * 30 days per month * 1 kWH / 1,000 WH = 21.6 kWH per month
If it wasn't for thieves, my life would be so very different.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Have mentioned that I see electronics do a lot of odd stuff. This light is slowly functioning better. The light is now off from to time. The head has quit rotating 100% of the time. Ughh. Intermittent problems are really the worst.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
Moisture and "real bugs" would be my first guess.
Second guess, the motion detectors (vs an actual camera based motion detector), use a thin semi-transparent white "lens" that focuses IR onto the sensor... And as the living object moves, the focus walks across the IR sensor. After a few years, I wonder if the plastic lens becomes opaque to IR light from UV solar exposure...
So cleaning the lens may help. My headlights also need refurbishing. I'll order supplies.BB. said:Moisture and "real bugs" would be my first guess.
Second guess, the motion detectors (vs an actual camera based motion detector), use a thin semi-transparent white "lense" that focuses IR onto the sensor... And as the living object moves, the focus walks across the IR sensor. After a few years, I wonder if the plastic lense becomes opaque to IR light from UV solar exposure...
This makes sense. That light gets the most exposure to sunlight.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
I don't know that cleaning will help. On my lights, the lens just shattered when I tried to clean (UV turned brittle?).-BillNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
There is a product that is marketed for something entirely different purpose that works excellent on plastics....it will clear up modern automobile headlites that "fog out" and others such as dash dials on older automobiles.....
Happich SemiChrome Polish......this is marketed for maintaining chrome on automobiles......it cleared all the dash gauges on my 1957 Volvo 444 in a few hours rubbing,they were so fogged that dials could not be read.. these parts are very rare and could not be found. This polish is very fine and does not leave scratches, not at all expensive and found in auto parts stores......2 Classic 150, 2 Kid, 5 arrays 7.5 kw total 2ea. 2S6P Sharp NE-170/NE-165, 1ea. 12P Sanyo HIT 200, 2ea. 4/6P Sanyo HIT 200, MagnaSine MS4024AE, Exeltech XP-1100, 2 Banks L-16 battery, Rolls-Surette S-530 and Interstate Traction, Shunts with whizbangJr and Bogart Tri-Metric, iCharger i208B dc-dc buck/boost converter with BMS for small form lithium 8S 16650 or LiFePO4, -
What works as well is toothpaste, the third world headlight polish.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
What is working very well so far is Deep Woods Off - for cloudy acrylic headlight lenses. Just rub it in with a cloth. No idea how long it will last.
I heard that stuff eats up your skin in about 20 years of steady usage FWIW.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
I tend to stay from using toxics, much better for your health. I have used toothpaste as a polish, it's very fine abrasive, Happich SemiChrome polish just works better, it's way thicker than toothpaste2 Classic 150, 2 Kid, 5 arrays 7.5 kw total 2ea. 2S6P Sharp NE-170/NE-165, 1ea. 12P Sanyo HIT 200, 2ea. 4/6P Sanyo HIT 200, MagnaSine MS4024AE, Exeltech XP-1100, 2 Banks L-16 battery, Rolls-Surette S-530 and Interstate Traction, Shunts with whizbangJr and Bogart Tri-Metric, iCharger i208B dc-dc buck/boost converter with BMS for small form lithium 8S 16650 or LiFePO4,
+1 on BB, The translucent "lens" are very fragile and will most likely crumble at the slightest touch. I've been through a bunch.BB. said:I don't know that cleaning will help. On my lights, the lens just shattered when I tried to clean (UV turned brittle?).-Bill
I recently bought a couple new style motion lights which don't have the lens and just have a small sensor opening. They seem very well made. Unfortunately I couldn't get them to work right and they would only come on when you literally touched the sensor opening. They are very bright though. I was refunded my purchase price on them and now I think I will hard wire them to a switch.
The security light has healed itself. Probably just dried out now that snow melt is no longer trickling into it. I did originally seal the top with silicone but outdoor seals tend to require periodic maintenance.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
It's been my experience that silicone won't stick well to much of anything (including itself once cured). It works okay as a sealant if it can be compressed a bit like a gasket after it sets up, but seems to invariably fail if surface applied.Off-grid.
