SOLAREDGE P320-5 SERIES DC OPTIMIZER with out thier inverter?
patdufo
patdufo Registered Users Posts: 9 ✭✭
SOLAREDGE P320-5 SERIES DC OPTIMIZER can these be used as a charge controller?I have 3 mision solar 295 w pannels,would these hook up to the batterires or do I have to have thier inverter?thanks.Also have eppever 40 amp mppt controllers on the rest but was given 6 of the solar edge free with used pannels also my system is 24v
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,198 ✭✭✭✭✭
    No. They are designed to work only with Solar Edge Grid Tie inverters.
  • BlackHoleSun_TN
    BlackHoleSun_TN Registered Users Posts: 8 ✭✭
    Are there any optimizers (Solar Edge or Tigo or Others) that can be used in off-grid applications? With or without inverters?
    Thank you.
  • littleharbor2
    edited February 2019 #4
    Tigo optimizers work in off grid systems.
    There is info out there, just didn't feel right posting other retailers info here. Look them up.
    LittleHarbor2 and the rest of the forum members,
    Links to other retailers that answer questions asked--Perfectly OK.
    -Bill "moderator" B.
  • BlackHoleSun_TN
    Thank you very much.
    I emailed TIGO and they gave me information on optimization off-grid.
    Does anyone have any experiences using them? Do they truly address shading concerns? Do they really increase effeciency?
    I am looking to use them on 14x Mission Solar Panels 360 MONO using a Schneider Electric MPPT80, and Schneider Electric XW+ 5548, to LiPO 48v Batteries.
    Thank you again.
    TIGO  optimizers can only masks the effects of shade, they don't make a fully lit panel any more efficient,
  • jonr
    edited March 2019 #8
    Say that you can sometimes optimize by 2% to 13% (see reference) over bypass diodes - usually less. I'd like to see an economic analysis that shows this is worthwhile (vs just adding more panels).
    https://www.solaredge.com/sites/default/files/se_technical_bypass_diode_effect_in_shading.pdf
