pv voltage for 48v inverter
robocop
robocop Registered Users Posts: 120 ✭✭
edited August 2017 in Solar Beginners Corner #1
Hi wvweybody
Back again after a while.
For a 48v inverter if the panels are 36 v how many should I use?
Or how can I match panels to a 48v inverter?
I see big 315w panel giving about 36v , should I look for  panel of 48v .?
How does that work?
Regards for everybody
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,198 ✭✭✭✭✭
    edited August 2017 #2
    A panel with a Vmp of Approx. 36 volts Would usually be a 72 cell panel. This is considered a 24 volt nominal panel. The 60 cell panels you see are typically around 30 Vmp. Some people will sell these as 24 volt panels but the thing is, once a 60 cell panel heats up in the sun the voltage will drop to a level that isn't high enough to charge or equalize a 24 volt battery. Power ratings on solar panels are created in carefully controlled conditions to assure all rating is done on a level playing field. In your case, to get a 48 volt NOMINAL output you would just series wire two 72 cell panels together. NOMINAL in this context  basically refers to battery based systems. What type of inverter are you trying to connect to?
  • mcgivor
    Normally the panels would be connected to a charge controller, which charges a battery, which powers the inverter. The charge controller specifications would dictate what panels can be used.
  • robocop
    would like to use rec 315w  solar panels  with a 5000w hybrid solar inverter low/high frequency??
    my total energy will be around 4000w .
    How many panels if only pv use for energy and if a combination of pv-batteries and grid use?
    Hope to have been clear
    thx
    Bob
    Ned more information on your loads,  location of install,  and what you are trying to do.
    400 watt  load x 10 hours per day = 4,000  watt *hours per day. But a 1,000 watt inverter would run that load.
    What do you mean with a hybrid inverter?  Grid Tied with off grid+battery bank?
    Emergency backup power? Have net meter utility agreement?
    GT Inverter + generator would be cheaper if you rarely have power failures,
  • robocop
    hi Bill  the load is 4000w  for 4 hours a day . it is grid tie . In the future net meter agreement  .Thinking of 8pcs  250ah batt  to form  500ah in 48v. Location is netherlands antilles
    Why not install a 3Kw grid tie system, with no battery ?  Do you really need backup batteries ?
    A 3 or 4Kw grid tie system would balance out your 4Kw load, and give you close to zero usage from grid.  (only on sunny days, clouds will deprive the panels of bright sun and power will be drastically reduced
  • Raj174
    Raj174 Solar Expert Posts: 795 ✭✭✭✭
    edited August 2017 #8
    Hi robocop,
     So the MPK 1800 hybrid inverter/charger that you were considering in a previous post, is the one you bought?. If that's the case, I have attached the spec sheet so the guys can take a look at it.
    Previous post:
    http://forum.solar-electric.com/discussion/351788/solar-system#latest
    Rick
    • 4,000 Watts * 4 hours per day = 16,000 WH per day
    Normally, for full time off grid, I would suggest 2 days of storage and 50% maximum discharge, or:
    • 16,000 WH per day * 1/0.85 AC inverter eff * 2 days storage * 1/0.50 max discharge * 1/48 volt battery bank = 1,569 AH @ 48 volt battery bank nominal
    I am assuming that this is way more than you really plan on buying (that is a relatively big battery bank for 16 kWH per day).
    The "minimum" flooded cell lead acid battery bank I would suggest for a 5,000 Watt AC inverter and/or 5,000 Watt PV Array would be ~500 AH @ 48 volt battery bank (if you want to charge/discharge the battery bank at a maximum/reliable rate of 1,000 Watts per 100 AH @ 48 volts).
    The size of a solar array that can supply 16,000 kWH per day for Willemstad N.A. with a fixed array would give you hours of sun per day of:
    Willemstad
    Measured in kWh/m2/day onto a solar panel set at a 78° angle from vertical:
    Jan Feb Mar Apr May Jun
    6.65
    6.95
    6.92
    6.23
    6.58
    6.78
    Jul Aug Sep Oct Nov Dec
    6.74
    6.61
    6.42
    6.41
    6.28
    6.32
    For an off grid power system, assuming a minimum of 6 hours per day (minimal AC backup genset usage):
    • 16,000 WH per day * 1/0.52 off grid AC system eff * 1/6.0 hours of sun per day minimum = 5,128 Watt array minimum
    However, if you are, mostly, running Grid Tied mode, then to make 16 kWH per day:
    • 16,000 WH per day * 1/0.77 grid tied AC system eff * 1/6.0 hours of sun per day = 3,463 Watt array minimum
    Then there is sizing the solar array for your battery bank. Normally, suggest 5% to 13% rate of charge for solar... 5% is good for weekend/seasonal usage (and with nominally grid tied system and afternoon brownouts?). 10%+ is suggested for full time off grid usage. Just to give you a range of ideas.
    • 500 AH * 59 volts charging * 1/0.77 panel+controller deratings * 0.05 rate of charge = 1,916 Watt array minimum (small battery bank with just "backup" charging)
    • 1,569 AH * 59 volts charging * 1/0.77 panel+controller deratings * 0.10 rate of charge = 12,022 Watt array nominal (large battery bank with full time off grid optimal charging)
    Just some discussion points.
  • robocop
    Hi Mike
    SO you think a 5000kva hybrid inverter is enough? Will use batteries when there is no sun.
    for instance about 4 hpurs in the evening if Not will use grid. So acombination
    How many pcs of panels of 300w?How tocombine panels for 48v inverter?
    Thx in advance   Bob
  • robocop
    Bil let me read and understand your explanation first
  • robocop
    Hi Rick
    No MUST  reveiver I have read their quality is not good and their service is bad
  • Raj174
    edited August 2017 #13
    Hi Bob,
    Possibly 12 or 14 of this type panel could be used, however it would require the use of a battery that does not need to be equalized. Likely an AGM battery, although some AGM's do require EQ, it's not at so high a voltage as FLAs. For a more accurate assessment, we need the specifications on the battery, charge controller and solar panels. Brand name and model numbers if possible.
    Rick
  • robocop
    good morning people
    Just thinking for a 4600 load 220v 50hz how many rec 315w panels ? inverter is 48v vdc input .
    Just a roughly calculation . Are the pv going up in price?
    4,600 Watt load for how many hours per day (you said 4,000 watts * 4 hours per day = 16,000 Watt*Hours per day). And I gave you a wide range of battery bank/solar array sizes.
    Off grid solar is expensive--Is there any way that you can reduce the loads (such as, if this is for air conditioning, can you replace the unit with a new mini-split system--more energy efficient--and insulate the home/room)?
    Is this for full time off grid, or just afternoon backups, or what?
  • robocop
    Hi Rick
    If I use the rec 315w panels and a MPP hybrid v series 5048, 500ah on battery pack for the 4600  load .
    How many panels do you think now. planning using a combination pf both PV-BATT-GRID.
    During the day pv and a couple of hours in the evening the batt pack
    I think this is the info you needed also for others people you are welcome to help me
    thnx Bob
  • Raj174
    Hi Bob,
    The MPP 5048 has an MPPT charge controller capable of 120 amps, will also support a 6000 watt array. Most AGM batteries will handle a 20 to 25% charge rate, however it would be helpful if you could provide the brand and model number of the battery. The last thing you want to do is lose a new set of batteries by charging them with too much amperage.
    Rick
