DC breakers
ws9876
Solar Expert Posts: 440 ✭✭✭
a search on the web for DC din rail breakers always brings up Midnite Solar units for 22 bucks. Is anyone else making DC breakers anywhere in the US that are cheaper..??
Midnite Solar breakers are competitively priced.
You can also look up Square D QUO breakers they have Din rail mounting and are rated for up to 48 volt systems. That being said They aren't recommended for higher voltage PV strings.
ws9876 said:a search on the web for DC din rail breakers always brings up Midnite Solar units for 22 bucks. Is anyone else making DC breakers anywhere in the US that are cheaper..??
https://www.solar-electric.com/midnite-solar-mnepv-15-amps-circuit-breaker.html
The above link was for an AC breaker here are DC offerings https://www.solar-electric.com/catalogsearch/result/?q=dc+circuit+breaker+
mcgivor said:The above link was for an AC breaker here are DC offerings https://www.solar-electric.com/catalogsearch/result/?q=dc+circuit+breaker+
- 628 Discussion Forums/Café
