New Solar Array and Core Charges, Ditch Lead?
BurntTech
Registered Users Posts: 8 ✭✭
I'm curious what others are doing for battery setups since core charges in MN are going for 20% of the cost of the batteries for Golf Cart batteries. The batteries them self aren't bad prices at about $91 after 10% for online orders but a $22 Core fee starts to eat into a 8-12 battery setup. Lithium powerwalls are starting to look like more attractive.
The core charge gets refunded when the bank gets retired, so it's really just the opportunity cost of tying up the core charge. If interest rates were 20% it would be a thing, but with rates near zero, not so much.Off-grid.
I would assume lead prices aren't going to bottom out but it appears all the core charges go with lead scrap pricing? Looks like buying bigger lead acid batteries doesn't seem to help much. Lithium rv style are still really expensive, so I guess it might be worth just riding a few hundred dollars on core charges?
Usually, core charges are set at a level that gets batteries to recyclers - they are one of the most recycled products in the world, so it makes sense there would be a relationship with scrap prices.Off-grid.
Core charges in California are set by state law.
I turned in a Costco battery, and they gave me back the old core charge (from my purchase history) even though the current core charge was higher.
- BillNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
Where I buy batteries a core is a core, whether I bought it there or not. If I have a core, they don't charge whatever the current core charge is. There's an arm's length government agency that runs recycling and gets fees like tire tax and I assume the core charges.Off-grid.
If I turned in a non - Costco battery, I assume they would give me the current core charge.
They refund the charge you paid, not the charge today, unless you bought it today.
If you are referring to core charges at Sam's Club (personal knowledge) or Costco (hearsay), They will take almost any battery as a core. I have used lawn tractor and motorcycle batteries at Sam's club. If it's not illegal, you might go around to lawn mower repair places, particularly shade tree guy's and pick them up for $6-8 dollars to use for cores.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
That is a good idea to look for salvage batteries, I was looking for junked golf carts for 6v batteries but it appears other people were thinking the same thing. I might start with a smaller battery bank and test using the inverter/charger/transfer switch with the off peak meter we have. With the solar and the batteries should be able to ride out outages when they turn off the meter. We use too much power to be offgrid for now. The first plan is to use as much solar without having to store it too long. we range from 2000kwH to 2500kwH for usage a month.
As for core charge and the future If you only buy the same batteries type and size you should be ok. Since in our area the core charges range from $10 to $60 depending on size. But just a heads up might be an issue if you wanted to upgrade types. I've also heard some places are very relaxed on trade in or core price per AH. I have a call in with a battery distribution company to see if bulk orders are same price but I expect they are. -
BurntTech said:I'm curious what others are doing for battery setups . . .
A local EV supply place (EVWest) has some very tempting Tesla modules - 3kwhr 57 volt at $212 a kwhr. But they are lithium ion, not lithium iron phosphate, and the risk of fire is too high for me.
I don't think it will take very long to start seeing core charges for other types of batteries too. Just think of it as an investment that will return the full value back to you in time.
@bill von novak
That's great bill, did you get the 18 180AH cells you had mentioned in a previous post? I have enjoyed using my LFP bank over the past year. Of course it's nice to have a full bank in the evening, but no worries about not getting a full charge or leaving them in a partial state of charge if you have to. Nice charge efficiency also. My only regret with LFP is not getting a bigger bank.
Rick4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
Raj174 said:@bill von novak
Solray said:I don't think it will take very long to start seeing core charges for other types of batteries too. Just think of it as an investment that will return the full value back to you in time.
Lead can easily be recycled in batteries. Lithium cannot. The other metals in Li batteries are more valuable that the Li.
https://waste-management-world.com/a/1-the-lithium-battery-recycling-challenge
The bottle deposit did not 'go away' in fact it increased in OR.
http://www.oregonlive.com/today/index.ssf/2017/03/ignore_the_label_oregon_bottle.html
It is for all bottles, not just glass ones, it includes plastic and aluminum as well.
Is it possible that some states regulate how much the core charge is? I know different stores in Pennsylvania have different core charges and lots of them will take any size battery to use as a core charge.
BB. said:Core charges in California are set by state law.
- Bill
I don't do much retail, but here in Texas I am forced to collect $2/battery under 12v and $3v for 12v or higher for retail level sales. That gets sent to the state as an "Environmental Recovery Fee."
"Core charges" around here are simply an income stream for retail battery sales people because junk lead-acid batteries are worth $.35/lb. on the recycle market - and people expect to give up their old battery.
It can add up when doing large change-outs. In 9 years of selling 2000 to 3000 batteries per year, I have never collected a core charge. But I have written a whole lot of checks for old batteries!
Marc
The fees you collect are the same thing as the core charge and for the same reason, to keep dead batteries off of the side of the road and out of landfills. Different states use different methods depending on the severity of the problem they face and other variables.
Selling batteries itself is just a revenue stream in and of itself. No one is selling batteries for cost out of the goodness of their hearts, not even the manufacturers.
https://comptroller.texas.gov/taxes/battery/faq.php
https://www.boe.ca.gov/pdf/l489.pdf
The $1.00 California battery fee will increase to $2.00 on April 1, 2022 -
Solray said:The fees you collect are the same thing as the core charge and for the same reason, to keep dead batteries off of the side of the road and out of landfills. Different states use different methods depending on the severity of the problem they face and other variables.
Selling batteries is indeed an income stream. That is the point of having the business. Is there a point to your comment, or did you miss the whole point about core charges?
I just realized that I got suckered in and I fell for it again! You seem to post just to get attention and/or get a rise out of people. It is a game for you two (three under the same IP?)
My problem is that I take this place seriously and I tend to forget that some people see it as their playground. You just love to argue and have posted to yourself under both (3?) screen names.
I will endeavor to stay clear of you.
Solray said:The bottle deposit did not 'go away' in fact it increased in OR.
Currently, there is a core charge for the valuable lead in lead acid batteries. The cost to reprocess Li batteries is higher than raw materials, which is why there is no core charge for Li. Maybe your state will put a tax on them for you and then you can feel good.
- 628 Discussion Forums/Café
