Mount Critique
Fatawan
Fatawan Solar Expert Posts: 71 ✭✭✭
I am zeroing in on my system design. I think I am going with the Sanyo HIT panels and Enphase 210's. I plan to go with 48 panels mounted in 8 rows of 6 each. I plan to mount the panels using 1 1/2" schedule 40 pipe into 12" concrete pillars. I will have three rows horizontally. The vertical bars will be made of aluminum 8020 extrusions u-bolted to the horizontal schedule 40 pipe. I'll use commercially available clips bolted to t-nuts in the 8020, and use the same t-nuts to mount the inverters. I have attached my crude side view.
Please critique and add whatever might be useful.
    Re: Mount Critique
    Cross bracing? (X or diagonal)?
  • Fatawan
    Re: Mount Critique
    Ah yes, bracing. I would imagine the whole tall row would need braced to one another, and perhaps back row to middle row? Is there somewhere to look up guidelines for bracing?
  • solarix
    Re: Mount Critique
    Make sure the pillars are well anchored, or really heavy. The wind loads can be tremendous. Figure about 10lb/sqft of wind pressure.
    Re: Mount Critique
    What he said...
    Yes depending on location wind might well be a really problem, we had 60mph straight line winds about 2 weeks ago, my panels were fine I have a ground mount with cedars and then my cabin, behind the panels, also a steeper orientaion for peak winter sun.
    The 4x8 roof over the archery range, broke the 4 - 4x4 posts at the ground. It was a new roof on older posts, but still quite impressive, it was just a roof out in the middle of a field.
    Re: Mount Critique
    Photowhit wrote: »
    ... it was just a roof out in the middle of a field.
    That's the worst situation you can have. If at all possible, put sides on the structure. Even slat sides will break up the wind and reduce the sail effect.
  • solar_dave
    Re: Mount Critique
    Yeah my neighbor put up a gazebo about 18 X 18 on just a set of framed up posts(2X4 box about 12 inch square with sheathing and stucco) , and the city would not approve the plans because of wind loading and lack of racking bracing. He put it up anyway. :confused:
    Re: Mount Critique
    He may find it in Kansas one day!
  • Fatawan
    Re: Mount Critique
    Anyone familiar with this mounting system? It's kind of what I had in mind, but I have no idea where it came from.
    Re: Mount Critique
    Looks like a spiffy ground mount, homemade ?
