battery shunt
andy300z
andy300z Solar Expert Posts: 39
Hello,
I am in the process of purchasing the trimetric 2020 battery monitor . I have a 24v system which will be 4 batteries 12v appx total 400ah. This is a starter set up which i will be adding more batteries in the future. Please advise on which shunt i should get a 100a or 500a. Thanks
  • mikeo
    mikeo Solar Expert Posts: 386 ✭✭✭
    Re: battery shunt
    I believe that you will need the 500 amp shunt for a system that size.
    Re: battery shunt
    Shunts are sized acording to how much current (amps) you expect to pull thru them. A 48V system that uses less current, can use smaller shunts.
    I would not try to get a shunt to match the peak surge current (motor starting), but would tend to size it to sustained loads.
    Re: battery shunt
    Remember that shunts have voltage drop too. To small of one may cause problems with surf currents.
