new 500 watt inverters for 2010
ws9876
Solar Expert Posts: 450 ✭✭✭
any good ones coming out ,sine, that are cheaper..??? its about the time ..... Also is there a good lug crimper for 6 awg and bigger that fits
in a manual 12 ton press..the car jack presses...
Re: new 500 watt inverters for 2010
I've been using a HF hydraulic crimper.. Looks like the price went up since I bought mine. Google for coupons!
I was using a hammer crimper in my bench press. Something about beating on wires just did not do it for me. The problem with the bench press is mobility. I've crimped a lot of ends on battery cables in cars. Removing the cables to take them to the press was a pain in the behind. -
Have you tried that hyd crimper on Anderson connectors?
Eric
I have not.
Planning on ordering some soon. I have to recover some lost savings from last month first. -
Harbour Freight also has this http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66396
I haven't used (or even seen this) but I've found most if not all tools from harbour freight servicable.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
i'm not sure if something like this is what you had in mind or not, but many hammer types can be put into a vice or press.
http://store.solar-electric.com/hacrtoforlal.html -
The manual hammer crimper works great. Not quite as easy to use as a hand crimper, but it works great.
As for HF stuff,, the operative word there is,,serviceable.
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
