getting 12V out of a 24V panel?
al128
Solar Expert Posts: 65 ✭✭✭✭
Hi there,
I have a Shell PowerMax Ultra 175-P panel with the following specs (copying the rear label here)
max power: 175w
short cir.curr: 5.43A
rated current: 4.95A
open circ. volt.: 44.6V
rated voltage: 35.4V
so this seems to be a traditional 24V (nominal) panel, right?
it has a : Junction box type: ProCharger™ IP54
more specs here: http://docs.google.com/gview?a=v&q=cache:YglMuM2RRkEJ:www.npp.ca/images/shellsq165-175.pdf+shell+powermax+ultra+175+solar+panel&hl=en&sig=AFQjCNH5A6WkKLOtB4EEr6_AuNM_KqgTUw
can I get the 175w in (nom) 12 v out of the panel or only in (nom) 24V form???
thx
al
max power: 175w
thx
al
Re: getting 12V out of a 24V panel?
You can only get 175W at 35.4V
You can use a MPPT type controller, and let it down-convert to 12V, then you would get 175W @ 14V (12.5A) remove 20% for warm panel losses.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
This is about the only reliable controller that will do that http://store.solar-electric.com/mosumpsochco.html
