Mounting question
gpt
gpt Registered Users Posts: 18
I have a roof that is 9x25 ft. If I fit 2 rows of panels 62 inches long, there will be a little bit of an overhang. Is it an acceptable practice to mount them so they are about a foot above the peak? Thanks in advance
    Re: Mounting question
    If a good gust of wind comes from that direction, you may see some breakage. Otherwise, they seem like they would sit there just fine.
    If this is a "building permitted" installation--you probably would need the signoff of a PE (Professional Engineer) anyway--And this should be exactly what he will be signing off for (based on the rating of the panels, racking system, and your peak winds in your area).
    Given that people mount arrays on exposed mounts (ground, tower, 1 and 2 axis trackers, etc.)--I don't see an issue unless the mounts are two far from the cantilevered ends (basically, the standard is to mount the rails 1/4 in from each edge. If not mounted this way, then the loads are not evenly distributed across the panel frame and mounting hardware.
    Unirac has some good information (even for the PE) on their rack mounting hardware... Looking through there may give you some ideas.
