Strings Moving
Hi Everyone,
I am facing an interesting problem during the lamination process.
During the lamination process, outer strings of the laminate are moving by 3-5mm causing two strings to touch each other. We do not know what will cause this? Can someone please help.
Thanks.
Thanks.
Re: Strings Moving
add an extra fold in the fabric before lamination, so it does not have to "pull" the edge in. It may take a while to figure how much to not get a wrinkle.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Strings Moving
if the raw cells are touching each other they can be conducting ( shorting out ) which is a very bad thing
