Inverter..with or without transformer
Can anyone indicate me a website or source that lists the plus points of having a solar inverter WITH a transformer as opposed to transformerless please?
Re: Inverter..with or without transformer
never heard of an inverter without a transformer.. and cant possibly see how it could ever be made. what is going to step up the voltage if not a transformer??magic candles? -
Transformerless inverters are commonly sold here in Europe and very often tender documentation specifically requests such inverters. Thats why im doing this research. -
Re: Inverter..with or without transformernever heard of an inverter without a transformer.. and cant possibly see how it could ever be made. what is going to step up the voltage if not a transformer??magic candles?
Magic FET's Lots of them
DC motor driven - AC generator ?
OMG !!
http://w1.siemens.com/press/en/pressrelease/?press=/en/pressrelease/2009/industry_automation/iia2009051934.htm
http://www.solarfeeds.com/ggs/6740-transformerless-grid-tie-inverters-lower-cost.html
It must be witchcraft!
NO , they CHEAT, and rely on the building's transformer:
http://www.pvworld.com/index/articles/display/0777426156/s-articles/s-Photovoltaics-World/s-volume-2009/s-issue-30/s-features/s-transformerless-inverters.htmlPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
AFAIK, some countries like the UK don't allow transformless inverters yet because of the lack of isolation. There are some grounding issues too - some thin film panels must be used with transformer inverters. Recommend you call someone like SMA and find out the pro's and con's of each. -
I think you are referring to 60 Hz isolation transformer.
Most low cost inverter have a high frequency boost circuit to take the battery voltage up to 155vdc for modified sinewave or 190 vdc for sinewave inverters. The boost circuit has a small high frequency ferrite transformer.
This high voltage D.C. is then chopped to produce the A.C. output through an H-bridge MOSFET output driver.
These type of inverters can not be neutral side of A.C. plug (the wider blade prong) grounded (bonded) to a house electrical box, without adding an external isolation transformer.
Also, inverter-generators less then 3kW also have the same H-bridge MOSFET circuitry and have the same issue of non-groundable neutral. -
I kinda think Ishould have read the OPa little bit better before saying anything.. I was only thinking he was asking about the usual sinewave /modified sinewave 12v /24v dc to 120/240 v ac inverters..:grr -
Re: Inverter..with or without transformerCan anyone indicate me a website or source that lists the plus points of having a solar inverter WITH a transformer as opposed to transformerless please?
Solar Guppy mentioned it in http://forum.solar-electric.com/showthread.php?t=5694 post #5
galvanic isolation I guess it's required in most places in UK & USAPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Just comparing the SMA kit, the transformless inverters offer:
- Slightly higher efficiency
- Slightly wider MPPT range
- Less weight -
Thanks for that...my main interest is in what the ADVANTAGES are of inverters that HAVE a transformer compared to transformerless... -
Re: Inverter..with or without transformerThanks for that...my main interest is in what the ADVANTAGES are of inverters that HAVE a transformer compared to transformerless...
A fault in the inverter electronics can not backfeed 240 VAC into the solar array when there is a transformer, its a major safety advantage -
Ideally, a transformer-less inverter should have some way of disconnecting the AC from the inverter in case of a fault. Either a relay or triac or SCRs or something like that.
boB
- 228 Forum & Website
- 618 Discussion Forums/Café
