new small wind co.s
ws9876
Solar Expert Posts: 453 ✭✭✭
Here are 2 more companiea.. TLG in Wisconsin makes a 1200 dollar 500 watt,TLG 500
with a Chinese alternator but looks ok. But is unimpressive on watts at 20 and 28 mph.
Wind turbines should be rated at 20-25 mph.
And a Canadian CO. Clean Energy in Calgary is making interesting Axial flux
machines like Hugh Piggot style but professional quality... in 1-50 kw and bigger.
Dont know their prices but Canadian outfits are never cheap.
If competition gets prices to a buck a watt complete,minus tower, people will be buying
turbines everywhere.Down with SWW and Bergey. OVERPRICED.
Re: new small wind co.s
A 500W 'mill that is un-impresive at 20 & 28MPH, is useless. Most residential areas seldom see >15mph wind, except in stormsPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
That's 20A @ 14V charging 12V batteries at 28 MPH, so claiming 280 watts, not 20. I'm building one with the same generator but the 1500 watt instead of 500 and 9-10ft rotor. Should be interesting. The main advantage I see with this alternator as opposed to the Piggott that the windings are around the outside of the aluminum housing, so heat can dissipated easier. -
are you referring to the Clean Energy alternator??? If so ,where did you buy it.??
do they have a USA dealer... and do you know anyone that has bought a full kit from
them and can comment on it??
It would be neat if you could stack 1KW modules next to each other to make a
2,3 KW without buying a whole new rig.
- 621 Discussion Forums/Café
