using solar panels with any modified sine wave inverter
Hi,
I just need help with 2 questions
1. can amorphous solar panels be connected in parallel with monocrystalline panels
2. Is it wise to join solar panels with a 3000watt modified sine wave inverter charger in parallel without damage to system
thanks
thanks
Re: wiring in parallel of modified inverter charger and solar panels
1) as long as their voltage under load, is about the same, it's fine. Look for a spec labled
VmaxP or VPmax
2) the question is not clear enough for me to understand what you are aksing to doPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: using solar panels with any modified sine wave inverter
I have a modified sine wave inverter with a 10 amp charger built in. This has to be attached to a battery/battery bank. It is said to be a UPS because if has automatic line transfer when AC power goes off. I would like to link my solar array of about 128 watts in parallel. Is this advisable.
Thanks for your input so far.
