Resource recommendations?
Re: Resource recommendations?
There are very few - if any - books currently available that are up to date.
Best bet is probably the Home Power back issues and articles www.homepower.com -
You might also try this book:
Photovoltaics: Design & Installation Manual
Found at: http://www.solarenergy.org/resources/store.html
I went through this book front to back before attempting to build my first system and it was a tremendous help.
-Todd -
Re: Resource recommendations?Jack-of-all.... wrote: »Which books and sources- if any- would you folks recommend ?
Roderick made an awesome DIY video:
http://forum.solar-electric.com/showthread.php?t=336
I took some home movies while installing our photovoltaic array.* There's no new information for the folks on this forum, but it might be some entertainment value, if you're trying to kill some hours on some dreary winter's night.* Or, if you have a friend considering an installation, this is a good intro to what was involved in my case.
http://www.archive.org/details/DIY_self_installed_solar_photovoltaic_panelsPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 228 Forum & Website
- 653 Solar Water Pumping
- 618 Discussion Forums/Café
