Can I combine 2 different solar panels?
I have an old, cracked 60W panel about 10-15 years old it looks like.
It produces 0.7 amps in full sunlight.
I want to buy a brand-new 115W panel.
Can I string these together and connect them both to my SolarBoost 2000E charge controller?
Thanks,
Matthew
Thanks,
Matthew
Re: Can I combine 2 different solar panels?
Matthew can you please post all the data from the back of the old panel, including make, and the make, model and specs for the 'new ' panel you wish to mate to the 'old' one..
thanks
Eric
Re: Can I combine 2 different solar panels?I want to buy a brand-new 115W panel.
Thanks, Matthew
You can series connect panels with like Amps
You can parallel connect panels with like Voltage (Vmp)
Frankly, I wouldn't bother with the cracked panel, exposed to the weather, even if it looks repaired, it won't likely last long, save the money, and get a larger primary panel.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
The old one is:
Holec (Serial # 008497)
Module HS.40.1
33.5 inches X 21.75 inches
They don't seem to have a website...
It has several long cracks on the front, and it only generates .7 amps at the most at 17.X volts.
I'm looking at a
BPSX-3115 115W
Which will deliver 6.85A @ 16.8V -
BPSX-3115 115W Which will deliver 6.85A @ 16.8V
In Hot Weather, you will loose voltage, (thermal coefficient of all solar panels) putting you very close to a non-charging situation. If not too hot, you will be OK Deep cycle batteries need ~15V to fully charge. Some voltage is "lost" in the charge controller.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
