Can I combine 2 different solar panels?
I have an old, cracked 60W panel about 10-15 years old it looks like.
It produces 0.7 amps in full sunlight.
I want to buy a brand-new 115W panel.
Can I string these together and connect them both to my SolarBoost 2000E charge controller?
Thanks,
Matthew
    Re: Can I combine 2 different solar panels?
    Matthew can you please post all the data from the back of the old panel, including make, and the make, model and specs for the 'new ' panel you wish to mate to the 'old' one..
    thanks
    Eric
    CathInfo wrote: »
    Thanks, Matthew
    You can series connect panels with like Amps
    You can parallel connect panels with like Voltage (Vmp)
    Frankly, I wouldn't bother with the cracked panel, exposed to the weather, even if it looks repaired, it won't likely last long, save the money, and get a larger primary panel.
  • System2
    System2 Posts: 6,290 admin
    The old one is:
    Holec (Serial # 008497)
    Module HS.40.1
    33.5 inches X 21.75 inches
    They don't seem to have a website...
    It has several long cracks on the front, and it only generates .7 amps at the most at 17.X volts.
    I'm looking at a
    BPSX-3115 115W
    Which will deliver 6.85A @ 16.8V
    BPSX-3115 115W Which will deliver 6.85A @ 16.8V
    In Hot Weather, you will loose voltage, (thermal coefficient of all solar panels) putting you very close to a non-charging situation. If not too hot, you will be OK Deep cycle batteries need ~15V to fully charge. Some voltage is "lost" in the charge controller.
