Can somebbody look up when I installed the last Cotek 24V inverter?
softdown
Solar Expert Posts: 4,062 ✭✭✭✭
All I can find is headlines. I apparently never made a post with a headline about employing the Cotek.
If I knew how long the last one lasted I would have a better idea about when to mostly retire the replacement Cotek. Four freezers of food is not a small loss.
I think it was about 4 years ago?
JustJRHill said:
Damn speech to text, I forgot to proofread that one. So sorry. It's been corrected."Girl enter your profile..."
Oh, wow.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
Here is a post of yours from 2016 talking about a purchase of a Cotek you made for a backup power system:
https://forum.solar-electric.com/discussion/comment/360586#Comment_360586
Using our forum search tools, you can search by author's name and content... Here is what I used for you:
https://forum.solar-electric.com/search?domain=all_content&query=cotek&scope=site&authors[0][value]=15993&authors[0][label]=softdown&source=community
Oh, wow.Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat. -
Was a bit surprised to find that. Cheap Mexican tequila perhaps?JRHill said:"Girl enter your profile..."
Oh, wow.I did a Cotek search yesterday and failed to find my previous posts. It only showed threads where Cotek was mentioned in the title. Unsure why entering my profile failed to help. Simple mistake I’m sure.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
The Cotek lasted for close to a decade. Operated four small/medium freezers for the past 4-5 years. So it did great all things considered.Had a power outage alarm on that circuit. The 9V battery was stone cold dead. Even if one invested in an outage alarm with rechargeable batteries - that may not last more than a few to several years.I just wrote 2025 on the case of the alarm - with a suggested battery replacement date.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
