New EASUN charge controller installed and went into “Night Mode, No Charging”.
softdown
softdown Solar Expert Posts: 4,034 ✭✭✭✭
Yet battery voltage is only 56.3. Default settings:
Bulk: 59.2V
Float: 58.4V
Absorb: 55.2V
I have the manual. It is maybe OK. Dancing with electronic keys is not my forte at all. I can’t even get the temperature off of the C/Celcius setting.
4.2 star rating. I have found ratings below 4.4 to indicate incoming issues. Which can usually be overcome with a time and anxiety price being extracted.
* Should I Just wait until tomorrow morning and see if it likes charging batteries sitting at ~ 48.4 volts?  This string is not required but I got it done for less than $250. So why not. Bad weather happens.
*Or drive myself nuts pushing, so far, uncooperative electronic keys? Maybe fix it? Maybe it is already ok?
  • softdown
    Correction edits stymied. Here goes: Bulk:58.4        Float: 55.2V
    What is the array voltage (specs/measured)?
  • softdown
    118 volts from three panels. Voltage taken right off of the panels.  145/150V charge controller.
    A lot could have gone wrong. I’ll troubleshoot further tomorrow. Or so.
    Dancing with electronic keys gives me the creeps. I’ve had some bad experiences. I am not real good at it.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,172 ✭✭✭✭✭
    I had a situation with a Midnight solar controller one time where the internal clock was wrong and it was doing something similar to what you're saying is happening. Check to see if there's a clock in that controller
  • softdown
    So I managed to blow up the panel diodes again. Doing the same thing as the last successful string - I think. Usually I don’t blow up diodes. Usually.
    There is something important that I forgot to do?
    Replacing the diodes underneath the panels will be pretty uncomfortable. May remove them for easier access.
  • softdown
    Didn’t blow up the diodes after all. Harbor Freight voltmeter quit working properly - lead then fell off.
    Back to remounting and troubleshooting. Solar can be a challenge for those not electrically gifted.
