Extreme soc charge in cold temp?
nyoffgrid
Registered Users Posts: 28 ✭✭
Hey all
I've been using my 200ah 24v battery and 3000watt inverter for about 6 months now in my off grid cabin. The warmer months were perfect. Even with all cabin running including ductless ac from 8am until 10pm the soc will be 80% at the end of the day. So I headed into winter thinking I'm good.
The last couple of times we came to the cabin this winter when night temp drops to 5-10 degrees.. the battery temp, per it's Bluetooth app, was 33f and soc was at 93% upon arrival we then used two 800 watt space heaters to just warm up until woodstove took over.. It dropped to 50% within less than 2 hours. It continued the rapid drop until I had to turn on generator..
Obviously temp is what causing this? I'm thinking to maybe try to try put that 800watt space heater right on battery (safely obviously) to try and warm it up quickly..
Any ideas/tips?
Any ideas/tips?
Give the team here specs on your system. Battery voltage and size will be especially helpful.Off-Grid in Terlingua, TX
The first thing that comes to mind is that your 1,600 watts of space heater load plus some inverter overhead, represents close to 17 % or 18% of your battery capacity, per hour that you operate both.In very round numbers: 200 ah battery x 50v = 10kWh. Two hours of heater operation is around 3.5kWh including some inverter overhead, which is 35% of your battery capacity.So, with your battery bank in brand new condition, starting at 93%, it would be at 58% running the heaters for two hours.I always have more questions than answers. That's the nature of life.
A very hard thing to do reliably ! Redesign the system is about all there is.
Winter is where the pedal hits the metal ! The days are getting longer😉"we go where power lines don't" Sierra Nevada mountain area
Now, factor in that it's a 24 volt battery.Marc Kurth said:The first thing that comes to mind is that your 1,600 watts of space heater load plus some inverter overhead, represents close to 17 % or 18% of your battery capacity, per hour that you operate both.In very round numbers: 200 ah battery x 50v = 10kWh. Two hours of heater operation is around 3.5kWh including some inverter overhead, which is 35% of your battery capacity.So, with your battery bank in brand new condition, starting at 93%, it would be at 58% running the heaters for two hours.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
One of the things that is not allowed in our off grid setup is resistance heat from a hair blow dryer and up. There has to be a better way to get the cabin warmed up without a major system redo? How about one or two of these (on their own grill bottle?) and a ceiling fan or two?
https://www.lowes.com/pd/ProCom-25000-BTU-Wall-or-Floor-Indoor-Liquid-Propane-Vent-Free-Infrared-Heater/5015729915?store=
When done for the season you can just store them away until next season. The ceiling fans, if you don't have them already, are useful all year around.Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat. -
Heaters vs batteries = no
Particularly cold batteries!Island cottage solar system with appriximately 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing due south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 31st year. -
A block heater for 15-30 minutes is an exception. Getting a machine started may be important than getting another layer of clothes on.Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
Yeah. I will be getting a pellet stove instead haha.
Will that be faster than a ventless propane? Still again you go to electric appliances in an off grid situation. That pellet thingy has a darn heating coil, screw and mandatory fan. I don't get it. But you can just go back to town....Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
At 0C/32F, a lead acid battery will lose about 20% of its capacity... And at 93% state of charge (SoC numbers are always a wild card), you would be looking at:
1.0 SoC (at 25C) * 0.93 SoC (measured) * 0.80 SoC (at 0C) = 0.744 estimated "usable" capacity
200 AH * 24 volts * 0.774 "actual" capacity/state of charge of your bank = 3,720 WH of usable capacity
1,600 WH * 2 hour = 3,200 WH of heater usage...
You would have left 520 WH of capacity after 2 hours of heating... Not a lot left.
3,000 Watt inverter on a 24 volt and 200 AH Lead Acid battery bank is expecting a lot... Typically on a 200 AH @ 24 volt bank would have been a maximum load of 1,500 Watt suggested.
Guessing this is some sort of Lead Acid battery bank? Not Lithium Ion?
PS, forget to add Lead Acid battery bank capacity vs Temperature link:
https://support.rollsbattery.com/en/support/solutions/articles/5860-temperature-vs-capacity-flooded-lead-acid-batteries
littleharbor2 said:
Now, factor in that it's a 24 volt battery.Marc Kurth said:The first thing that comes to mind is that your 1,600 watts of space heater load plus some inverter overhead, represents close to 17 % or 18% of your battery capacity, per hour that you operate both.In very round numbers: 200 ah battery x 50v = 10kWh. Two hours of heater operation is around 3.5kWh including some inverter overhead, which is 35% of your battery capacity.So, with your battery bank in brand new condition, starting at 93%, it would be at 58% running the heaters for two hours.Whoops! My mistake.I always have more questions than answers. That's the nature of life.
- 232 Forum & Website
