Using a 400w DC to DC Step-Up Boost Converter to Charge Batteries Using Genset?
genocell
Registered Users Posts: 9 ✭
Hi,
I stumbled upon this on ebay while looking to build a custom 12v to LCD power adapter. There's also an interesting video review explaining how this thing works.
I am currently building a solar system with an 25 amp mppt charge controller doing off grid. I'm thinking of using this as a battery charger during sunless days and emergencies by connecting the boost converter between my small gas generator's dc 12v 8.3amp outlet and my charge controller. Essentially boosting the generator's dc power outlet acting as a surrogate for a set of 300 watt panels to the charge controller.
I know people would say to just get a charger but this thing is cheap and I think more efficient than to use a ac to dc battery charger. I can use my small genset instead of my big multi kilowatt genset. In addition I can use it as my LCD computer monitor power supply when it's not in use as a surrogate battery charger saving me money.Do guys think this will work?
Any reply and helpful advice will be greatly appreciated.
Re: Using a 400w DC to DC Step-Up Boost Converter to Charge Batteries Using Genset?
DON'T !! the generator's 12V output, is only 96 watts, @ 48V that's just under 2 amps. not much.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Using a 400w DC to DC Step-Up Boost Converter to Charge Batteries Using Genset?DON'T !! the generator's 12V output, is only 96 watts, @ 48V that's just under 2 amps. not much.
Oh okay then. Didn't notice that now that you mentioned it. Guess I have to buy that charger. Thanks. -
Can’t find a step up converter at our host. Amazon has this with a 4.3 star rating. The true 48 alternators are both very expensive and poorly rated. https://www.amazon.com/Converter-EAGWELL-Regulator-Adapter-Vehicle/dp/B0B7WZGCM3/ref=sr_1_10?crid=12TPRAZ6TOJOG&dib=eyJ2IjoiMSJ9.i6Ec6EBKBp7AoTjEj46-OcS4VtauoHbMDwU1C47ufmV-i5Rbq3ky9XX3uhthmQH0-inZIsoQdBmfGQys5vDezsquH-y6GGPFL4dPFC0XgqwhzW3-LoWPT81KMS6-First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
Thinking the wind generator was “rated" at 600 watts. So this step up converter may be too small.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
Here is a 480 watt unit with a 4.6 star rating - but only 18 ratings.https://www.amazon.com/Cllena-Converter-Voltage-Regulator-Transformer/dp/B0CKRX92Q8/ref=sr_1_5?crid=1P9CSG73CH8P2&dib=eyJ2IjoiMSJ9.QT5wJ8wmNrZo3bU3-First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
960 watt unit for ~ 3 times the price. $200.https://www.amazon.com/Cllena-Converter-Voltage-Regulator-Transformer/dp/B0CKRXSMNR/ref=sr_1_5?First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
- 227 Forum & Website
- 617 Discussion Forums/Café
