bms 250a 16s not working
install the BMS 250a 16s according instruction but the BMS wont start the batteries checked and the pack gives about 56v.
did make a short between P- and B- and nothing happen..
Can anyone gives me clue how to ?
Did not attached the controller as connecting to the batt only should work.
Awaiting your reply
Bob
Your battery will not come alive until it is connected to a charging source. After connecting the controller try jumping it again to wake up the controller.
Hi I did connect the controller and I got the lcd screen working of the smart inverter but still the fan is not working.
what are the most important I have to check on the screen? and the soc screen what is that tells me?
Now a door has been open for me thnks little harbor -
Soc screen should show how much current is going into the battery or is exiting the battery. Is it charging?
yes is changing going higher value . still the fan of the smart bmns not working only a green light on and off at the balancer
j -
I would imagine it would come on only when it needs to.
I cannot still get it working on my cellular although I did pair it with my bluetooth it gives two codes that both will not work. Do you something about that?
I'd be just guessing, sorry. The fan shouldn't be working Is all I can say. If you are pushing the BMS hard I guess it would come on. I have a Daly BMS without any bluetooth so that's no help but I will say I have never heard the fan working in two years now. I wouldn't worry.
I purchased four EVE 105Ah LiFePO4 cells and a DALY BMS from Neexgent to try assembling a pack myself. Initially, I didn't know how to do it and sought after-sales service, but I didn't receive the appropriate guidance. I watched many videos on YouTube and learned how to assemble it on my own.
https://www.neexgent.com/product/neexgent-eve-3-2v-105ah-lifepo4-cell-lithium-ion-solar-battery-grade-a-li-ion-battery.html
Look at all the money you are saving!Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
- 228 Forum & Website
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
