Resetting the Outback 3648
softdown
Solar Expert Posts: 4,062 ✭✭✭✭
Mine has a hair trigger circuit breaker. It shuts down faster and easier than my household circuit breakers. That would be OK but the only way I can seem to reset the Outback is to disconnect the battery bank cables then re-connect.
I tried the inverter switches including leaving them off for a minute or so. Nothing works except for disconnecting the battery bank. In my case that is a bit of a hassle.
Anybody know the magic trick?
This inverter requires an OutBack MATE3S system display and controller. You have this right?
Yes
I prefer using the charge controller over the MATE, I find it far more intuitive.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
How is it done?First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
