SW 4024 dies every time I try to set the inverter to run
Richard55
Richard55 Registered Users, Users Awaiting Email Confirmation Posts: 2
having problems now. when I try to set the inverter, from 50 amp shore power, to invert the screen goes blank and it turns off
  • Richard55
    do I need to junk this inverter and go to a victron inverter?  It appears to have a shorted out mother board. very sad
    Dave Angelini Solar Expert Posts: 7,079 ✭✭✭✭✭✭
    Is it a CSW 4048 or as you wrote a SW 4048 ?  How do you know the "mother board is shorted out" ?
  • littleharbor2
    50 amp shore power is 220 split phase. Which SW do you have? The original ones are only 110 single phase.
    Hmm I think you are a little short on being right on shore power.
     In all the marina's I have been the typical 50A service is 120vac or in Europe 250 volt single phase.
  • littleharbor2
    Didn't realize that. I'm picturing a 4 prong plug.
  • littleharbor2
    I see 3 prong plugs as well. Wow, that's a lot of power for a single phase.
    OP is probably in the state of Georgia USA
    Bill
    Very Big boats/ships can be wired for whatever the Marina or Dock can supply. Just takes an electrician to wire it up.
    Single phase is the norm because that is what is on the Yacht, in most all cases.
    Georgia for sure!
