SW 4024 dies every time I try to set the inverter to run
                    Richard55
                    Registered Users, Users Awaiting Email Confirmation Posts: 2 ✭
                    having problems now. when I try to set the inverter, from 50 amp shore power, to invert the screen goes blank and it turns off
            do I need to junk this inverter and go to a victron inverter? It appears to have a shorted out mother board. very sad
            Is it a CSW 4048 or as you wrote a SW 4048 ? How do you know the "mother board is shorted out" ?"we go where power lines don't" Sierra Nevada mountain area
            50 amp shore power is 220 split phase. Which SW do you have? The original ones are only 110 single phase.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
            Hmm I think you are a little short on being right on shore power.
 In all the marina's I have been the typical 50A service is 120vac or in Europe 250 volt single phase.
            Didn't realize that. I'm picturing a 4 prong plug.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
            I see 3 prong plugs as well. Wow, that's a lot of power for a single phase.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
            OP is probably in the state of Georgia USABillNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
 Very Big boats/ships can be wired for whatever the Marina or Dock can supply. Just takes an electrician to wire it up.littleharbor2 said:Didn't realize that. I'm picturing a 4 prong plug.
 Single phase is the norm because that is what is on the Yacht, in most all cases.
 Georgia for sure!"we go where power lines don't" Sierra Nevada mountain area
- 232 Forum & Website
