Please Help
InclusiveDesigns
InclusiveDesigns Registered Users Posts: 1
Hey everyone! Quick history...bought a 99 mckenzie travel trailer with 1 slide. No batteries, water heater disconnected thermostat disconnected.
We bought a battery from Walmart for $90 and seems the 12v system works. I am low income with 3 kiddos and this will be our home until further notice. HELP! I want to make this trailer able to function without shore power as renting a spot in a rv park is out of my budget right now. We live in oregon. Please can someone walk me through what I need to do. Please no negativity.
    Photowhit Solar Expert Posts: 6,024 ✭✭✭✭✭
    Not sure what you are asking?
    Do you want to setup to run on Solar? This WILL NOT run an electric water heater, or basically anything that heats or cools. It might run lights and charge laptops during the day, provide some minimal TV or radio on sunny days.
    The Walmart battery is likely NOT a true deep cycle battery, but will work for a while. A 200 watt array (solar panel/panels),
    A couple of these and 'y' connectors;
    https://www.renogy.com/100-watt-12-volt-monocrystalline-solar-panel-compact-design/
    a charge controller, this one would be long term reliable,
    MidNite Solar Brat PWM Solar Charge Controller 12 and 24 Volts | Northern Arizona Wind & Sun (solar-electric.com)
    and small inverter. You could use a car inverter, but a pure sine like this one will produce a clean sine wave, easier on electronics;
    Victron Energy Phoenix 12/500 120V NEMA 5-15R Inverter | Northern Arizona Wind & Sun (solar-electric.com)
    Propane heat and fridge might be okay but a repeatable expense, 20lb/4.4 gallon tank every 3-4 weeks for fridge.
    Dave Angelini Solar Expert Posts: 7,120 ✭✭✭✭✭✭
    Not negative but realistic! In Oregon it will be very hard for solar to work this time of year. You sure there is no other way???  Below is from Costco. Good Luck
    A-iPower 1800W running/2300Peak Powered by Yamaha Inverter Generator
    Item  1443507
    Model  SC2300I
    4.6 out of 5 stars. Read reviews for average rating value is 4.6 of 5. Read 1299 Reviews Same page link.
    4.6
    (1299)
    Write a review
    Your Price
    569.99
