if i recall -- after a firmware change or change in grid code, you need a power cycle reboot. Not just killing ac power, but also kill the 48v supply from the battery. Completely die the box and then reboot.
hybrid: two xw6848 pro with five mppt60, 13 kw pv 17 cell Eve 280ah LiFePO4 storage 14 kw (now at 3 banks) total 40 kw gridtie: sunny boy sma 2x 5k Gateway / Insight Local
