good site
ws9876
Solar Expert Posts: 453 ✭✭✭
You probably know this guy but I just found him. Sharp dude on Lith Iron batt cells from China.
https://www.mobile-solarpower.com
You Tube
1800$ for 48v 100 ah. that's not cheap but....?
If someone had a 12 volt RV what could they do with a batt pack like this..?
You Tube
Might look for a 12 volt version of a 5 kWh battery bank.
Here's one put together from a US company, $1500 for a 12 volt 400ah;
EG4-LifePower4 Lithium Battery | 12V 400AH - Signature Solar
In RVs from the factory all the wiring and controls are built in and generally not great quality.If I was install the eg4
in a RV like that, what additional control would I need ? The original systems are all lead acid...and I assume they get charged
by the engine too ...32 ft Thor motorhome with slides. stock... -
You may want to research the eg4 batteries before purchasing. Alot of problems with the BMS. Have a nice day. GeorgeOff grid for 20 years. 5KW panels, Trace sw4024, Bergy XL1 wind generator, 3 EG4 Lifep04 200amphr batteries 3 SQF 2 well pump, 12kw back up gen. Not easy living in the wilderness but it keeps you busy
Higher quality RV manufacturers have great wiring design/implementation in my experience.Nowadays, big RVs are migrating to 24v battery banks to feed their larger inverters. They use a stepdown converter to feed the comparatively small 12v loads. I don't know how big your RV system is, but you may want to consider a 24v core system if you have a large inverter.I always have more questions than answers. That's the nature of life.
- 230 Forum & Website
