How to fix holes in asphalt shingles?
Well, I measured everything down to the inch. All my rail mounts hit their target except for one. I had to move the drilled hole over several inches leaving some 3/16” holes in a trail. I’m thinking I should simplify bite the bullet and have the roofer who did our roof three years ago to take care of this. Thoughts?
    I'd let the pro fix it.
  • Ralph Day
    Ralph Day Solar Expert Posts: 1,038 ✭✭✭✭
    The pro will probably use some kind of sealant/caulk...NOT silicone.  If it's under the panels no problemo, that close it's probably under the overhang of the panel anyway.  A good flexible caulk will do the job.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,187 ✭✭✭✭✭
    If you have access to the lower edge of that tab you can use a flat bar, (super bar) to lift up the tab and slide a piece of step flashing or a single thick piece of a comp shingle up under the tab. That, along with a little roofing mastic will be a permanent fix.
