Would like to power my home refrigerator.
Stinky3773
Registered Users, Users Awaiting Email Confirmation Posts: 1 ✭
An average, efficient fridge will consume about 1 - 2 KWh per day.
Do you get cloudy days? weeks ?
Using solar to power a refrigerator is probably the most difficult/expensive with the least payback thing in solar.
Unless you are replacing a propane fridge. Then it is very cost effective.NANOcontrol said:Using solar to power a refrigerator is probably the most difficult/expensive with the least payback thing in solar.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year. -
Stinky3773 , Are you interested in operating cost savings? If so, it is very hard to make a financial case for solar vs. grid power. I would assume that you are looking for some level of autonomy when grid power goes down?
- 230 Forum & Website
