Would like to power my home refrigerator.
Stinky3773
Stinky3773 Registered Users, Users Awaiting Email Confirmation Posts: 1
edited May 2022 in Solar Water Pumping #1
    An average, efficient fridge will consume about 1 - 2 KWh per day.
    Do you get cloudy days?  weeks ?
  • NANOcontrol
    NANOcontrol Registered Users Posts: 280 ✭✭✭
    Using solar to power a refrigerator is probably the most difficult/expensive with the least payback thing in solar.
  • 706jim
    706jim Solar Expert Posts: 524 ✭✭✭✭
    Unless you are replacing a propane fridge. Then it is very cost effective.
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,190 ✭✭✭✭
    edited May 2022 #5
    Stinky3773 ,  Are you interested in operating cost savings?  If so, it is very hard to make a financial case for solar vs. grid power. I would assume that you are looking for some level of autonomy when grid power goes down?
