Secondary Charge controller
Hey guys I’ve talked with a few people and here is my scenario,
I have two strings coming back from my second pv array #10 two negatives and two positives
Coming back to a 60 VictronConnect  mppt
im looking at some information at how to combine these properly and what kind of protection is needed prior to adding it to my inverter.
A line diagram would be amazing thanks ahead of time.
    Photowhit Solar Expert Posts: 6,024 ✭✭✭✭✭
    I think you need to explain a bit more about your situation.
    Traditionally your array would go to a charge controller then into your battery/system. Also they would usually be combined at the array and a single set of connectors brought to the Power Center (Charge controller, Inverter, with breakers/fuses)
    Are you saying "60 VictronConnect  mppt" is your charge controller? If you have 2 sets of coming from your array because they have different VMP/IMP then you should use 2 different charge controllers.
    To properly figure this out, what is needed, system nominal voltage and the VMp of the strings of solar panels would be needed.
