Can panels be installed without being hooked up yet?
showme
showme Registered Users Posts: 94 ✭✭
I'm finally getting started with our solar project, and I'm about ready to put up our modules. I'll have 2 top of pole mounts with 12 modules each (LG Neon2 320w). I've got the 8" poles set, have one MT Solar rack started, and I'm setting the rails today. I want to get the panels mounted and the rack up and secure before bad weather hits. I still have to put up the building to temporarily store our power equipment until we build our house there this spring.
My question is, how do I wire (or not) my array so that it will not damage them until I get the rest of the system up and running? I'm not sure if I need to leave the wires disconnected, connect each panel's +/- wires, or what? Do I need to cover them with tarps until ready?
Leaving them till later is not an option. Thanks, Lee
"Knowing is not enough, we must apply. Willing is not enough, we must do."   Goethe
2006 Trace Xantrex power panel, (3) SW5548 inverters- 2 NOS Trace's (1999) and 1 Trace/Xantrex 2006 for back up (came with power panel. et al), Xantrex DC/disconnect, Xantrex AC disconnect/bypass, (3) C40 PWM charge controllers- 2 NOS, one used. (8)Evergreen  Solar 120w (960w),  8k LG Neon 2, (25) 320w, Bergey XL.1 1.5k genny, Air X 400 genny (came with used system), 48v Interstate Workman batts (now frozen/toast), (2) Montana Solar adjustable Top of Pole 12 array racks, (2) Midnite Solar MSPV 4 combiner boxes, (2) Midnite Solar Classic 150's (one an SL), SOK LiFePo stack of 500ah and one nice Ozark hilltop to set them all on.
  • 706jim
    706jim Solar Expert Posts: 524 ✭✭✭✭
    Wire them up now but be sure to cap off the wire ends so that you don't accidently shock yourself or anybody else.
  • Wheelman55
    Wheelman55 Registered Users Posts: 252 ✭✭✭
    And do the final wiring in the evening or early morning when there is no sun on the panels.
    Off-Grid in Terlingua, TX
    5,000 watt array - 14 CS 370 watt modules. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 390ah LiFeP04 battery bank - 3 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries
  • wellbuilt
    wellbuilt Solar Expert Posts: 763 ✭✭✭✭
     I did this , we just let the bank sit until every thing was set up .
     I finished the array at nite with head lights .
     I have a breaker panel now so no problem .
    I'd wire the panels into their disconnect box, and then , leave it in the Disconnect position.
    NO REASON TO EVER WORK IN THE DARK!!!
    Properly wired the panels should be wired to an open breaker or an empty fuse.
  • showme
    Thanks for the replies, folks. I found this interesting post on a physics forum https://physics.stackexchange.com/questions/71434/where-does-electricity-go-from-a-solar-panel-that-is-not-plugged-in-to-anything, that is pretty interesting. Seems plugging the two leads together is the option I'm going with right now. Keep the plugs from corroding and zeroing out the current. I'd love to wire it up now, but I'm using MT Solar racks that use a chain fall to lift it into place. Until I get the rack up and attached where I want it, I can't jump the chain fall and lifting rig to the second pipe to get it started. The bad part is, everything is at shoulder level right now. Much better than working off a ladder. I'll report back with an update.
    BB. Super Moderators, Administrators Posts: 33,705 admin
    I am not sure I agree with the link on what happens with a "disconnected" solar panel...
    The voltage generated by a cell is correct--Around 0.5 volts Vmp (voltage maximum power) per cell when connected to a load... But when not connected, the panel generates around 0.7 volts Voc (voltage open circuit). The reason is the "diode junction" goes into "conduction" to "clamp" the voltage at 0.7 volts. So there is current flow and heat developed (power=voltage*current -- Which is true even for a diode).
    So, an "unconnected" solar panel will "run hotter" if disconnected (energy stays "in-panel") vs a panel connected to a load (electrical energy is "transported" "off-panel").
    Now a typical residential solar panel is something like 12-18% efficient--So that "extra heat" generated in-panel will not raise the panel temperature much higher than a load connected panel (12-18% "more energy" as heat in panel).
    There are solar panels that must be connected to loads/short circuited if left in the sun. These panels (as far as I know) are only used in large commercial solar farms (if they are even still produced these days?). In this case, the panels will have "issues" if left in sun for more than a week or so in full sun "unconnected" (some sort of thin film panel as I recall).
    Note that the standard MC4 solar connectors are not rated for a large number of make/break cycles (a few connect/disconnect cycles are not going to be an issue). And disconnecting the connectors under current flow (loads, shorted panel under sun)--The connectors can arc and damage the mating surfaces (very thin gold layer over base metal)... So I would not suggest shorting/opening MC4 connectors on a panel under sunlight.
