Schneider XW Pro and a miniPDP do they work together
I am asking here because I have searched the Schneider docs and they confirm that the full PDP will work with the XW Pro but NOWHERE is it confirmed that the mini will work
Sure I can assume they will work together, but I want full confirmation up front
thanks
    XW's are all physically the same. Drop me an e-mail please.
  • shawnj72
    shawnj72 Registered Users Posts: 64 ✭✭
    Physically the XW/XW+ and Pro are the same Dimensions. The Pro Being Rule 21 and UL1741 complaint. Fits like a glove.
  • dougbert
    dougbert Registered Users Posts: 5 ✭✭
    great -  appreciate the confirmations - their docs on the XW Pro only indicate the full PDP
  • Gutaz
    Gutaz Registered Users Posts: 6 ✭✭
    @shawnj72 Know this is an old thread, but how was the setup of the XW Pro and stability.  Seriously considering this with mini-PDP myself.  Will be installing and setting up myself with inspection.
    both my old 6048 and new 6848 sat right onto the midnight ePanel for the XW series, everything lined up with both
  • shawnj72
    @Gutaz , I apologize for the Delay. I havent visited here in quite some time. If I had to do again I would.. It has really worked flawless and a Great combination. Setup was fairly Straight Forward. been going strong since install. Hope it Helps.. Regards.
