solar battery recharge systems for running weather stations
bretmon
Registered Users Posts: 1 ✭
Hi, everyone thanks for accepting me.
Just a question ? New to this so bear with me. I have been running a relatively cheap weather station, in fact this is my second one. The system came with a solar recharge panel located and attached above the battery compartment. After reading up on the problems associated with these systems ;IE battery compartment had to be out in the sun so the solar array would charge, and the problems with bad weather, heavy rain, allowing water to enter the battery compartment and causing issues. I have since removed the solar panel and moved the battery compartment under cover to protect it from the elements (which made the solar array de-funked) and now use rechargeable batteries via an indoor plug in type battery charger.
The problem, of cause means regularly changing the rechargeable batteries, on around a monthly basis, (very annoying) other than that the system works very well.
My question is ?? I have a solar array charging a spot light that is used very rarely but is handy none the less. The array panel came with the spot light and runs a chord to the solar panel and plugs in to the spotlight. I am wondering if perhaps it would be possible to link that array to my weather station to charge the batteries as well as the spot light batteries ??? Since the spot light is only used on rare occasions the batteries don't need to be charged as often but would serve to charge the batteries on the weather station.
Hope that all makes sense, Look forward to any responses and suggestions if any like minded people have done this.
Thankyou.
What voltages does the spotlight & weather station run on ?
A 4.5V panel for the spotlight won't do much at all to recharge a 12V WS battery.
