Rejuvenating Taylor Dunn SC-100-24 battery cart?
softdown
Solar Expert Posts: 4,062 ✭✭✭✭
So I took a chance on this cart at a Ritchie Bros timed auction. They provide minimal information of timed auction lots - that usually fetch less than $500. Paid $280 figuring the batteries might be worth more than that. Few people have significant battery knowledge it seems.
But there are only 4 golf cart type batteries. They were put into service in 2015. Trying to rejuvenate the 24 volt system right now. The battery voltage was very low - around 2.5 on 3 out of 4 batteries. One battery seems much newer - that battery gets hotter when charging.
No keys for ignition. Plus completely derailed tires - looks like the cart was shoved sideways with no air in tires.
Thinking it might be great for my 80 year old uncle who still farms in spite of losing a lower leg in his youth. With a carrying capacity of about 400 pounds it may also prove useful for my fledgling tree and lot clearing enterprise. At 62 - I can't carry the weight I used to.
These sell for $7000 new. Useful input?
Poster here because the greatest questions regard the battery array. They show 27 volts under charge - 20 volts shortly after charger is disconnected.
Looks like a neat solution for your uncle...
May want to look at the roads/paths your uncle uses. Figuring out how to put wide/dual tires on it to better avoid sinking into soft spots (and then the issue of how to get it free). If soft/mucky ground--I fear those tires are a bit on the small side (larger diameter would be good too--But then other issues such as gearing and room for tires).
And--That thing is really calling out for an electric which of some sort.
Otherwise, for your needs over unimproved land--Perhaps you can find a deal on two wheel tractor sort of power unit (and articulated trailer):
https://en.wikipedia.org/wiki/Two-wheel_tractor
With the right wheels+tires--They seem to be used heavily in swampy rice fields and such.
Anybody know a way to bypass the key function? If a car can be hot wired then a cart can also be.
BB. said:Looks like a neat solution for your uncle...
Well I just got myself a Navigator 5500 forklift. But at 8 1/2 feet wide it is not currently super portable. Still - coolest toy ever.
Skid steers are just ridiculously expensive. They do not depreciate like one would expect. Plus I need high flow with about 110 HP and 10,000 lbs. or more. To properly run tree mulching/land clearing equipment.
It would be difficult to properly get into the business without spending at least $300,000 - though I am trying hard.
So the three 2015 batteries have charged to 6 volts. The newer battery died while charging with the rest however. Sitting at 3.5 volts.
Another day will likely take the three up to 6.3/4 volts.
Uncle seems interested in the cart.Can't hardly imagine something less useful than three marginal 6 volt batteries.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Schematic for your cart?
https://www.manualslib.com/manual/1536684/Taylor-Dunn-Sc-100-24.html?page=88#manual
Whole manual:
Batteries--Perhaps you can get them charged enough to debug the cart--But probably going to need a new set for operation(?).
Got a key that works. But only one battery held at 6 volts. It has a built in 24 volt charger - that periodically makes a clicking sound - every few seconds. Makes the proper sounds but not enough voltage to do anything but make sounds.
Think I'll buy a few batteries and donate it to my uncle. Seems he could use it on the farm.
- 234 Forum & Website
