Conext Gateway and CSW Events
Nitr0
Registered Users Posts: 3 ✭
I installed a CSW4024, Battery monitor and Conext gateway in February. I was wondering if I have something configured wrong or if it will not show me in the event log that I failed over to battery and then back to grid. I fail over to battery several times a week and I get notifications from a UPS that I have plugged into another circuit not on my critical loads panel. The only events I have ever seen in the even section were when I was having battery charging issues (which have since been resolved). So I know that the events section works.
Also, I'm at the latest firmware version on all devices.
Conext Gateway - v1.12 build 450
CSW4024 - v3.12.00 build 1
BatteryMon - v1.01.00 build 100
Should show history of events back as old as COMBOX in 2009 if you had a system that old. Did you check logs? I do not have a CSW in my system rather an XWP. You should see something also in the SCP faults and warnings for each device as well as system.
I checked Logs and there are no logs besides Sev: Information. They are all from source SCB. I don't have an SCP because it was out of stock everywhere I tried to get one since December. Is this possibly why I don't have the alerts?
