Putting modified sine inverters through breaker panel
powerinthewoods
Registered Users Posts: 7 ✭✭
I have 2 2000 watt modified sine inverters that I want to put on my breaker panel. I have a transfer switch to select generator or battery bank. I’m planning on 1 inverter on each phase of the main panel. (No 220v) The problem is the bonded neutral. My inverters can’t Handel that. How do I proceed?
Hmmmm , there is a little green screw in the panel that grounds it . Remove the screw .Then check for ground .It’s kinda risky working with no ground and it won’t pass inspection ☹️Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
What Wellbuilt is referring too (in detail)--MSW inverters usually do not have "transformer isolation" between the DC input and the AC output...
Normally we tie the DC battery bank negative to earth/safety/green wire--That is for safety (i.e., if a + VDC lead shorts to metal sink/plumbing/electrical box, the current finds it way to safety ground then to negative battery bank terminal--This pops the DC + Fuse or Breaker).
And in North America, we do the same thing for AC utility power... The "Neutral Wire" (white wire/neutral bus) is tied to the same ground rod earth ground/cold water pipe/electrical box grounds.
With MSW inverters, if you tie the DC negative (or positive) ground terminal to the AC white/neutral terminal, you will short circuit the MSW inverter and less the magic smoke out of the inverter.
If you do not "ground reference" the battery bank (let it float)--You will not have a short with the grounded neutral. And now the "battery bus" is "Hot" with respect to ground.
OR, you ground reference the battery bank (i.e., negative ground), and float the L1 and L2 output of the MSW inverter--That will work...
HOWEVER, again in North America, for safety we ground reference the 120/240 VAC neutral bus to safety ground--And as Wellbuilt says, no ground bonded neutral makes your house wiring non-compliant with code, and "unsafe" for NEC compliant wiring.
You can do "anything"--But the NEC (national electric code) is designed around the whole requirement that the white wire/neutral is ground referenced. This allows you to only install 1 pole circuit breakers for 120 VAC circuits (just on the black or red wires--White, no breaker)...
For "floating" outputs, you need to have 2 pole breakers--One on the Black/Red and a second on the White wire--Which no North American home has (you need a third "neutral bus" with breakers).
Your only safe (and possibly code compliant) installation option is to install a mixed utility power/backup inverter power system is to use a TSW/PSW (true/pure sine wave) inverter (which almost always have transformer isolated outputs). And a properly designed/installed DC/AC/Transfer Switch system (true transfer switch or AC interlocks on main/sub panel).
MSW inverters are really only for stand alone power, or if you use a sub panel with a 2 pole (at least) transfer switch that disconnects both Hot and Neutral from AC mains, and connects to L1 & L2 MSW AC output... If your MSW inverter is >1,800 Watt output @ 120 VAC--Then you should use a (120/)240 VAC panel with 2 pole ganged breakers (one bus to L1 and the second to L2)--You will only get 120 VAC (not 240 VAC), but it will be much safer (both L1 & L2 wires from MSW inverter have breakers).
The problem with doing things "different"--Is the next person to work on the system (electrician, other than you)--They will be pretty confused about what you did and how to repair/upgrade.
I don't see any safe way you can wire this MSW inverter to your main panel safely/to code.
^^^^^^^^^^^^^^^ this
thanks bill great explanationOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
Hi everyone. The easiest way would be for me to purchase different inverters. If I had 2 true sine inverters the bonded neutral issue would be solved?
The 2 inverters need to be of a style that will sync with each other unless there is ZERO chance of any 240V appliances.
There is no 220 volt in the cabin. 1 inverter for phase A and 1 for phase B. Gives me 4000 watts running over the 8 circuits of the panel.
Backing up a moment...
You have 8x circuits and only need 120 VAC.
How much Wattage do your need? Both running Watts and starting surge (i.e., a typical compressor 120 VAC fridge/freezer takes about 5-6 amps to Start, 4-5 amps to defrost (if "frost free"), and around 1.0 amps running compressor).
Typically, for a cabin with AC inverter fridge, LED lights, cell phone charger, 12 volt (or 24 volt) RV Water pump, etc. needs a minimum of ~1,200 to 1,500 Watt 120 VAC inverter. And a battery bank (say 24 volts and 3,300 WH per day--a very efficient home/cabin with energy star rated fridge/freezer, LED lights, small laptop computer, RV style DC water pump):- 3,300 WH per day * 1/0.85 AC inverter eff * 2 days storage * 1/0.50 max planned discharge * 1/24 VDC battery = 647 AH nominal battery bank
- 647 AH * 2 9.0 volt battery bank * 1/0.77 solar panel+controller deratings * 0.05 rate of charge = 1,639 Watt array minimum
- 647 AH * 2 9.0 volt battery bank * 1/0.77 solar panel+controller deratings * 0.10 rate of charge = 3,277 Watt array nominal
- 647 AH * 2 9.0 volt battery bank * 1/0.77 solar panel+controller deratings * 0.13 rate of charge = 4,620 Watt array "typical" maximum
http://www.solarelectricityhandbook.com/solar-irradiance.htmlDartmouth
Measured in kWh/m2/day onto a solar panel set at a 45° angle from vertical:
Say you will be using the system (using solar) for 9 months of the year, and shut down and/or using genset in winter:Jan Feb Mar Apr May Jun 2.90
3.71
4.39
4.46
4.62
4.85
Jul Aug Sep Oct Nov Dec 4.90
4.82
4.62
3.83
2.65
2.28
- 3,300 WH per day * 1/0.52 off grid AC system eff * 1/3.71 hours of sun per day (February break even) = 1,710 Watt array (Feb break even)
And about your panel--Not connected to any utility power--You could simply connect the A and B buses in the present breaker panel to L1 (Hot) from your inverter/genset, and connect the Neutral bus (grounded if TSW/PSW) to White on your inverter/generator (assuming sine wave inverter).
MSW inverters are "cheaper" than typical PSW/TSW inverters... And for some loads even more efficient... However, refrigerator compressors, some battery chargers (and tool chargers), and some electronic power supplies "do not like" MSW wave from (modified square/sine wave). They can overheat and/or make a 120 HZ bus.
You don't want to exceed the current rating of your circuit breaker panel (say it is rated at 120/240 VAC 80 amps)--You would not want to exceed 80 Amps @ 120 VAC (p=v*i= 120 VAC * 80 amps = ) 9,600 Watts @ 120 VAC -- Which is way more than you are planning (4,000 Watts for you plan, vs 1,500 Watts for "my" plan).
Not saying the above is written in stone or that my guesses are "right" and yours are "wrong"... Just putting some sticks in the sand for basic system / back of the envelope design--Which is much cheaper to do on paper than to start buying hardware.
In general, it is almost always cheaper to conserve energy (most efficient, use as little electricity as practical for your lifestyle) than to have a larger system to generate "more power".
Your thoughts?
I have a full panel here the main breaker it just a on off switch
With 30 breaker ?
The cabin is wire like a on grid home
I use no 240 volt
both legs of my panel are just power with a jumper from pole A to pole B
I Use one inverter out back3600 watt 48volt system . The system just works .The inverter charges the battery’s allso
I see no advantage in running 2 inverters .My system has one ground point @ the inverter .Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
Wow, you guys take this stuff very seriously . I’m more of building and learning as I go. If the solar array I put together isn’t enough(1500watt with 500ah storage) I’ll fix it as I learn. I have to start somewhere without breaking the bank. Thanks guys for all the comments and please keep them coming! The cabin is mostly weekends 12 months a year. Also thinking of wind in the near future. What are your thoughts on that?
Many here have learned through experience, much like what you are doing now, learning as you go, in many ways that is the best, but heeding advice will save money in the long term.
Overestimating the availability of energy stored in batteries is the most common mistake followed closely by undestimating the requirements needed to return the withdrawals plus interest as solar modules do not produce their rated output and batteries along with the electronics needed are not 100% efficient.
Wind in most cases is not worth the effort or expense, invest in solar as panels are currently extremely inexpensive, unless your trees look like this, in which case wind may be a viable option.
Remember these two things, shortcuts will slow you down and don't go broke saving money.
Well said. My lot is 15 acres with a grade to the River. The high point of the property has a fair amount of gentle breeze to 20kph wind. There is a 6 acre lawn on the south side of the cabin that the sun wraps around as the day goes by. That side of the roof is 350 sqft. Plenty of space for a larger array if needed. Maybe I’ll stay out of the wind until I learn more!
Hi guys. It’s been a while. I have purchased a new 24volt pure sine inverter. (4000/8000)still nervous about connecting it to the cabin’s breaker panel. I don’t want to see smoke. Any words of wisdom?
I did not find a manual anywhere... If you have one, make sure to read it closely.
The min/max voltage for the 12 VDC version was 9/15.5 volts.... Taking your battery bank under 11.5 volts (under medium loads--or 23.0 VDC for 24 volt bank) can quickly wear out/fail if taken to "dead". 15.5/31 VDC max charging voltage is "OK" (many older units are 15/30 VDC max volts)--If you were in a very cold sub freezing climate--The temperature corrected charging voltage could exceed 32-33 volts (in Canada, some folks have to shut down the inverter when charging/EQing battery bank).
The small units showed battery clips... For any reasonably larger AC inverter--Always use bolt up connections--Battery clips/jumper cables will not cut it.
Regarding grounding.... Check the negative DC terminal and metal chassis against both AC output terminals... Should be very high resistance (floating output). If you see zero Ohms between battery negative/chassis ground and "AC Neutral", then the Neutral is bonded between AC Neutral output and Negative/chassis ground. Larger inverters and gensets can come with AC Neutral to Ground bonding... Most North American AC main breaker panels have a tie between neutral and ground connections.
Technically, if your inverter and AC main panel are both grounded--Nothing bad will happen. And you do not have GFI (ground fault interrupter)--So no false trips with two grounding locations. In Code, you only want one AC Neutral+Ground bond (don't want AC power flowing in green wire ground).
4,000 Watt @ 120 VAC output:- 4,000 Watts / 120 VAC = 33.3 Amp nominal
- 4,000 Watts / 110 VAC = 36 Amp at lower voltage
Here is a relatively conservative (NEC/Local code has a lot more design parameters). Suggest >=40 Amp rated wiring from inverter to panel:
https://lugsdirect.com/WireCurrentAmpacitiesNEC-Table-301-16.htm
For DC input... 4,000 Watts is good size DC load:- 4,000 Watts * 1/0.85 AC inverter efficiency * 1/22.0 VDC typical battery cutoff voltage = 214 Amps max continuous current (round up to next standard wire/fuse/circuit breaker size) Suggest DC Circuit breaker so you can shutdown inverter when needed to service/leave property for a period of time
https://www.calculator.net/voltage-drop-calculator.html?necmaterial=copper&necwiresize=12&necconduit=steel&necpf=1&material=copper&wiresize=0.4066&resistance=1.2&resistanceunit=okm&voltage=120&phase=dc&noofconductor=1&distance=5&distanceunit=feet&eres=213&x=0&y=0&ctype=nec
Voltage drop: 0.13
Voltage drop percentage: 0.11%
Voltage at the end: 119.87
Should be fine... Suggest a maximum of 1.0 VDC @ 24 volt battery bus as max drop...
Make sure good cooling (don't mount in sealed closet, don't mount under shelf, etc.)...
Do you need a transfer switch of some sort? Utility/Genset/2nd AC inverter to main cabin panel?
I have a transfer switch(65 amp)Also have DC breakers to isolate panels if needed. I still need a 200 amp fuse in front of the inverter. Do I need a fuse on each line coming from the battery bank?
- 626 Discussion Forums/Café
