Need BTS/15 battery temperature sensor
technovelist
Registered Users Posts: 18 ✭✭
I think my search for an SWRC remote controller for my SW4024 has been successful; I'll know in a few days if it arrives and works as expected.
But now I have another problem: one of my BTS/15 battery temperature sensors was damaged somehow.
Does anyone know where I can get one of these?
Thanks!
Thanks!
Don't know if this helps, but I have a temperature compensation stick on style battery temperature sensor for my old Trace C40. If that would work you would be welcome to have it. Not before May though as it is marooned on our island until breakup.Island cottage solar system with appriximately 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing due south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 31st year.
706jim said:Don't know if this helps, but I have a temperature compensation stick on style battery temperature sensor for my old Trace C40. If that would work you would be welcome to have it. Not before May though as it is marooned on our island until breakup.
I have a bunch of them. I'm in Northern Baja. I'd be happy to ship you one for the cost of shipping if you want.
littleharbor2 said:I have a bunch of them. I'm in Northern Baja. I'd be happy to ship you one for the cost of shipping if you want.
You folks can use Private Messages to exchange addresses and contact information.
If all else fails they pop up on Ebay frequently.
AND, just to state the fairly obvious,
The BTS is primarily used during charging from the inverter, and if this charging is usually done manually (not with AGS), then, one could adjust the charge voltage manually, if needed to adjust for battery temperature.
Am not certain if the LVD-type functions are temp comped on these venerable Trace inverters.
Think that these BTSes are a 100 K Ohm NTC Thermistor (dunno the curve factor), connected to a phone plug.
Just as an aside, Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
technovelist said:706jim said:Don't know if this helps, but I have a temperature compensation stick on style battery temperature sensor for my old Trace C40. If that would work you would be welcome to have it. Not before May though as it is marooned on our island until breakup.Island cottage solar system with appriximately 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing due south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 31st year.
My email reply got returned so here's the textThey are pretty bulletproof. I can't imagine wrecking one. I really don't want to give up more than one. If that's fine with you let me know and we'll precede. BTW I'm heading to the states on Tuesday so I would just send it from up there and save some excess shipping and time.Mike McCormick
littleharbor2 said:My email reply got returned so here's the textThey are pretty bulletproof. I can't imagine wrecking one. I really don't want to give up more than one. If that's fine with you let me know and we'll precede. BTW I'm heading to the states on Tuesday so I would just send it from up there and save some excess shipping and time.Mike McCormick
Vic said:AND, just to state the fairly obvious,
Just as an aside, Good Luck, Vic -
Chewing type animals (rats, mice, rabbits, etc.)? Look for where they "sampled" the insulation (but not necessarily bit clean through).Some types of insulation really attract animals--Others not so much.-Bill "have pet rabbit, or 3 year old with wire cutters... Can't tell the difference) B.Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
- 225 Forum & Website
- 617 Discussion Forums/Café
