Need BTS/15 battery temperature sensor
technovelist
technovelist Registered Users Posts: 18 ✭✭
I think my search for an SWRC remote controller for my SW4024 has been successful; I'll know in a few days if it arrives and works as expected.
But now I have another problem: one of my BTS/15 battery temperature sensors was damaged somehow.
Does anyone know where I can get one of these?
Thanks!
  • 706jim
    706jim Solar Expert Posts: 526 ✭✭✭✭
    Don't know if this helps, but I have a temperature compensation stick on style battery temperature sensor for my old Trace C40. If that would work you would be welcome to have it. Not before May though as it is marooned on our island until breakup.
  • technovelist
    edited March 2021 #3
    Thanks, that may help. Would you happen to have a picture of it? Does it look like this? https://www.infinigi.com/xantrex-bts15-battery-temperature-sensor-w15ft-cable-p-229.html
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,182 ✭✭✭✭✭
    I have a bunch of them. I'm in Northern Baja. I'd be happy to ship you one for the cost of shipping if you want.
  • technovelist
    That would be terrific. What would the cost of shipping be to East Texas?
    You folks can use Private Messages to exchange addresses and contact information.
  • Saggys
    Saggys Solar Expert Posts: 189 ✭✭✭
    If all else fails they pop up on Ebay frequently.
  • Vic
    edited March 2021 #8
    AND,  just to state the fairly obvious,
    The BTS is primarily used during charging from the inverter,   and if this charging is usually done manually (not with AGS),   then,  one could adjust the charge voltage manually,  if needed  to adjust for battery temperature.
    Am not certain if the LVD-type functions are temp comped on these venerable Trace inverters.
    Think that these BTSes are a 100  K Ohm NTC Thermistor (dunno the curve factor),  connected to a phone plug.
    Just as an aside,   Good Luck,   Vic
  • 706jim
    Yes, that's the one. It looks like you've found one easier to get your hands on but if it falls through just let me know.
  • littleharbor2
    My email reply got returned so here's the text
    They are pretty bulletproof. I can't imagine wrecking one. I really don't want to give up more than one. If that's fine with you let me know and we'll precede. BTW I'm heading to the states on Tuesday so I would just send it from up there and save some excess shipping and time.
    Mike McCormick
  • technovelist
    Mike McCormick
    Yes, one is fine. The reason I need a new one is because my previous one got cut in several places somehow, but I'll be more careful with this one. I'll try private messaging you again, since it appears the previous one didn't go through for some reason.
  • technovelist
    Thanks for the info. I never charge manually but only from the grid or generator via the inverter, so I think this is pretty important.
    edited March 2021 #13
    Chewing type animals (rats, mice, rabbits, etc.)? Look for where they "sampled" the insulation (but not necessarily bit clean through).
    Some types of insulation really attract animals--Others not so much.
    -Bill "have pet rabbit, or 3 year old with wire cutters... Can't tell the difference) B.
